Pocket GPS World :: View topic - POI's
POI's
ahooks
PostPosted: Fri Jul 07, 2006 4:00 pm    Post subject: POI's Reply with quote
I've looked over this forum as much as I can but can't find the answer anywhere! I've just bought a Nuvi 300 with the maps and a Speedcamera POI's pre loaded on the internal memory (No SD Card was supplied)
What I'd like to know is as the speed cam's are pre loaded, if I upload a load of POI's from http://www.MaFt.co.uk/garmin/ this will automatically overwrite the poi file with the cams on it. So can I A) Have two POI files on the device or B) export the current speedcam poi's on the device back to csv so I can include them with the new POI's from the above link?? Clear as Mud?! Confused
Perhaps an option C would be: Can you have a poi file on the device and another one on an SD card....would it use both or just one poi file?
I hope it makes sense!!
Many thanks
Adrian
RODTROTTER
PostPosted: Fri Jul 07, 2006 4:52 pm    Post subject: Reply with quote
you need to put all the pois in the same folder b4 you upload them they will overwrite theones that are on just pop the speed cams in with all the other pois then off you go no problem
ahooks
PostPosted: Fri Jul 07, 2006 5:08 pm    Post subject: Reply with quote
Hi, thanks for a quick response. However, the speed camera poi's were pre-loaded so I don't have the original csv files. Crying or Very sad
Without being able to either get hold of the original csv files from the place I bought the unit from 2 days ago, or extract the current poi file back to a csv file then I I'll lose them if I add more poi's via the uploader
Adrian
timber
PostPosted: Fri Jul 07, 2006 5:33 pm    Post subject: Reply with quote
Adrian
Welcome to the forum,
£2.00 and you will have the latest Camera Database for your nuvi just complete the subscription at http://www.pocketgpsworld.com/subscription.php
Now for the Garmin POILoader software be aware that the latest version has a bug that treats all poi's the same as cameras you will have alarms going off as you aproach halfords/asda/petrol stations every poi that is loaded.
Get the previous version from http://makeashorterlink.com/?C41E2306D
and the poi's will operate as intended Thumbs Up
timber
PostPosted: Sat Jul 08, 2006 2:27 am    Post subject: Reply with quote
Link is not working Exclamation as pointed out by original poster here is the direct route
http://www.gpsinformation.org/perry/POILoader_20.exe for the benifit of others.
22.071 (03 Jul 24)
