jackarmy83 Occasional Visitor
Posted: Sat Jun 17, 2006 2:21 pm Post subject: i3 and locating satellites |
Hi all,
Just bought an i3 and updated it to the latest firmware revision. (3.10). Just got in my car to test it out but it's stuck on locating satellites (tried for 10-15 mins).
Does it need to be activated first? No mention of what to do in the user manual that comes with it.
Thanks, Karl |
Posted: Sat Jun 17, 2006 2:32 pm Post subject: |
As usual, I've done things arse backwards. Just read the faq section. So will try the advice given there first.
dougconran Regular Visitor
Joined: Oct 07, 2004 Posts: 175 Location: Bury St Edmunds, Suffolk
Posted: Sat Jun 17, 2006 2:33 pm Post subject: |
No, it doesn't need to be activated first but it can take some time to locate satellites the first time you switch on.
Make sure it is outside, has got plenty of open sky around, and doesn't move about at all. If you haven't got a lock in about 30 mins (I think) then you've probably got a problem
HTH |
Posted: Sat Jun 17, 2006 2:52 pm Post subject: |
Thanks Doug, just been up on the roof of my flats and it picked it up within about 5-10 mins. :D
Thanks again. |
jizzer Occasional Visitor
Posted: Sun Jun 18, 2006 8:40 pm Post subject: |
Thats still a long time I had this problem with the latest firmware(3.10) then rolled back to V2.7 now locks on to sats in under a minute ....always keep a set of batteries in the unit even if you use the cig adaptor this way it sort of retains its memory if you like and locks on quicker |
north_country_boy Occasional Visitor
Posted: Sun Jun 18, 2006 9:42 pm Post subject: |
Mine used to lock on in a few seconds on 2.7, now i'm on 3.1 and it took 15 minutes today, not happy, Garmin should sort this out  |
Posted: Sun Jun 18, 2006 11:09 pm Post subject: |
jizzer wrote: | Thats still a long time I had this problem with the latest firmware(3.10) then rolled back to V2.7 now locks on to sats in under a minute ....always keep a set of batteries in the unit even if you use the cig adaptor this way it sort of retains its memory if you like and locks on quicker |
Maybe I didn't explain myself clearly.
I meant it took 5-10 mins for the initial satellite locations (as it was the first time I was using it). Now it picks them up straight away. |
supercliff Occasional Visitor
Posted: Mon Jun 19, 2006 1:38 pm Post subject: |
I've found that my i3 can take up to 5 minutes to locate satelites if I haven't used it for a while, esxpecially if I get on the move before turning it on.
But, if I'm at home, it latches on in seconds.
Weird.... _________________ Nuvi 660, VW GOLF
