Pocket GPS World :: View topic - Can you load european
DCFC_79
PostPosted: Fri Jun 16, 2006 11:25 pm    Post subject: Can you load european Reply with quote
maps onto the i3,
oldfogy
PostPosted: Sat Jun 17, 2006 1:44 am    Post subject: Re: Can you load european Reply with quote
DCFC_79 wrote:
maps onto the i3,
DCFC,
It's probably best to put the whole question in here and not rely on the forum topic as being part of your question. If it is, that is?
But sorry I don't know the answer for you.
Re: Can you load european maps onto the i3
(If it ain't broke, I can soon fix it)
nudda
PostPosted: Sat Jun 17, 2006 10:11 am    Post subject: Reply with quote
I would also like to know this so if someone could help that would be great !
zogman
PostPosted: Sat Jun 17, 2006 12:19 pm    Post subject: Reply with quote
there are many posts on this item- do a search ...but briefly yes you can put european maps on the i3 if you buy city slect/navigator europe and a blank card ....
DCFC_79
PostPosted: Sun Jun 18, 2006 8:12 pm    Post subject: Reply with quote
where does the card go though
mhb
PostPosted: Mon Jun 19, 2006 8:49 am    Post subject: Reply with quote
With the screen of the i3 facing you, on the right hand side you will see the usb port. Just below that there is a recess with a 13mm long by 2mm wide slit in its base. The card is slid into there until it locks in position.
You might know already but in case you don't, you can buy cards with various european country maps already loaded on them but they cost around £90 each.
DCFC_79
PostPosted: Wed Jun 21, 2006 11:42 am    Post subject: Reply with quote
much appreciated for your help mhb, where can you purchase the cards with the maps on
bumpkin
PostPosted: Wed Jun 21, 2006 5:08 pm    Post subject: Reply with quote
try http://www.thenavigationcompany.com/productaccessories.php?productkey=830, only found via Google search though so can't recommend one way or the other.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
mhb
PostPosted: Thu Jun 22, 2006 7:09 am    Post subject: Reply with quote
For preloaded SD cards try
http://www.mynewcheap.co.uk
or
http://www.globalpositioningsystems.co.uk
mhb
PostPosted: Thu Jun 22, 2006 7:17 am    Post subject: Reply with quote
Sorry DCFC_79, the last of the two above links is wrong. It should have been
http://www.gpsw.co.uk/cats/cl3_306.html?Skip=10&
nudda
PostPosted: Thu Jun 22, 2006 8:58 am    Post subject: Reply with quote
ive already forked out a lot on city navigator ... do I still need these cardS ? What are they "preloaded" with ?
Beerbellybill999
PostPosted: Thu Jun 22, 2006 9:22 am    Post subject: Reply with quote
If thats the case your licence should allow to be loaded on to two units and if you have the unlock code you will be able to load it to any transflash card. I 512mb card costs around £15.
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
nudda
PostPosted: Thu Jun 22, 2006 9:43 am    Post subject: Reply with quote
excellent thanks
22.071 (03 Jul 24)
