DIXYEMMIE Occasional Visitor
Posted: Wed Jun 14, 2006 11:11 pm Post subject: DOWNLOAD CAMARA DATABASE |
HI IAM NEW TO THIS DOWNLOAD LARK, I HAVE TRIED TO DOWNLOAD THE SPEED CAMARA FILE TO MY NAVMAN ICN 530 AND WHEN I GO TO THE POI FILE IT COMES UP WITH "UNKNOWN FILE FORMAT" WHAT IS THIS?PLEASE
THANKS |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Wed Jun 14, 2006 11:51 pm Post subject: Re: DOWNLOAD CAMARA DATABASE |
DIXYEMMIE wrote: | HI IAM NEW TO THIS DOWNLOAD LARK, I HAVE TRIED TO DOWNLOAD THE SPEED CAMARA FILE TO MY NAVMAN ICN 530 AND WHEN I GO TO THE POI FILE IT COMES UP WITH "UNKNOWN FILE FORMAT" WHAT IS THIS?PLEASE
THANKS | Your CAPS LOCK is stuck on.
At what point does your problem occur? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Wed Jun 14, 2006 11:56 pm Post subject: |
Hi when i go into the POI Editor and go to open text file then go into folder for the file then click ok to open it comes up with the message
thanks |
Posted: Thu Jun 15, 2006 12:16 am Post subject: |
DIXYEMMIE wrote: | Hi when i go into the POI Editor and go to open text file then go into folder for the file then click ok to open it comes up with the message
thanks | If I remember correctly, there are 2 different formats that you can use on the Navman (CSV & ASC?) one of them needs to be edited (first line deleted?). Is that any help? _________________ Jock
Posted: Thu Jun 15, 2006 3:42 am Post subject: |
Are you sure you have downloaded the correct file type? you need the .asc files and these no longer require the text edit to the first line have a read through this guide http://www.pocketgpsworld.com/uksafetycameras-navman.php it explains the installation routine on the Navman system in detail
One other thought, you have un-zipped the downloaded file so it shows the different files withing the download before using the POIEditor? - Mike |
Posted: Fri Jun 16, 2006 12:23 pm Post subject: |
Thanks guys problem solved.
Which of the 3 camera files is the best to download?
thanks |
Darren Frequent Visitor
Posted: Fri Jun 16, 2006 1:09 pm Post subject: |
DIXYEMMIE wrote: | Thanks guys problem solved.
thanks |
That depends on your preference. The single file version does not differentiate between camera types, the consolidated by type version does and the speed zoned version separates every camera by speed. Each one takes more time to install in that order with the speed zoned taking the most time. _________________ Darren Griffin |
