cairdy Occasional Visitor
Posted: Wed Jun 14, 2006 1:36 pm Post subject: speed cameras |
please can you explain why the data base tells you that the speed camera
recorded speed is incorrect.(iE)a14 43.this should be 70.a406 into London 31 this should be 50.i have downloaded the data base for my i3 Gamin. |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Wed Jun 14, 2006 1:45 pm Post subject: Re: speed cameras |
cairdy wrote: | please can you explain why the data base tells you that the speed camera
recorded speed is incorrect.(iE)a14 43.this should be 70.a406 into London 31 this should be 50.i have downloaded the data base for my i3 Gamin. | I don't have the i3, but I think you'll find that the database is correct, but that the setup on your i3 needs to be set to MPH rather than KPH. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Wed Jun 14, 2006 4:37 pm Post subject: Re: speed cameras |
BGF wrote: | I don't have the i3, but I think you'll find that the database is correct, but that the setup on your i3 needs to be set to MPH rather than KPH. | On reflection, it may be the software that you use to transfer the cameras to the i3, rather than the software on the i3, that has to be set to MPH/KPH. _________________ Jock
Posted: Wed Jun 14, 2006 4:48 pm Post subject: |
Reload the database again to your i3. This time make sure POILoader is set to Miles per Hour and not Kilomters per hour.
This has been asked dozens of times before....... |
Posted: Wed Jun 14, 2006 10:29 pm Post subject: |
PaulB2005 wrote: | Reload the database again to your i3. This time make sure POILoader is set to Miles per Hour and not Kilomters per hour.
This has been asked dozens of times before....... | There's an echo in here...ere...ere _________________ Jock
Posted: Mon Jun 19, 2006 2:43 pm Post subject: |
MPH OR KPH,THANKS TO ALL FOR YOUR HELP. |
