moswick Occasional Visitor
Posted: Mon Jun 05, 2006 2:57 pm Post subject: poi's for navman 720 |
i have downloaded speed camera file for navman and saved in a folder on desktop, when i try to install csv files onto 720 from this folder there are no csv files there |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Mon Jun 05, 2006 6:35 pm Post subject: |
The Navman Files are ASC Files. They are Text Files and the Data is laid out the same as the CSV Files.
The difference is that the CSV File has a header, which Navman doesn't need, or use.;) _________________ Richard
Posted: Wed Jun 07, 2006 2:52 pm Post subject: |
so how do i now install pois |
Posted: Wed Jun 07, 2006 5:26 pm Post subject: |
Read the helpfile here. Although it was written for the Safety Camera database, it holds true for all custom POIs. Click on my www button for a link to a website containing some POIs. _________________ Tim |
Posted: Thu Jun 08, 2006 3:09 pm Post subject: no files showing |
thanks for your advice but i still have same problem, i save camera files to a folder on desktop then active sync my navman 720 then open smart st desktop 2006, when i clickon map then points of interest the box that opens only asks for csv files so as new camera database files are asc they do not appear in the box so there is nothing to import. i have had no problem importing poi's before with my navman 520 so i have some experience |
Posted: Thu Jun 08, 2006 3:20 pm Post subject: Re: no files showing |
moswick wrote: | thanks for your advice but i still have same problem, i save camera files to a folder on desktop then active sync my navman 720 then open smart st desktop 2006, when i clickon map then points of interest the box that opens only asks for csv files so as new camera database files are asc they do not appear in the box so there is nothing to import. i have had no problem importing poi's before with my navman 520 so i have some experience |
That's strange. The Desktop POIEditor has never specifically asked for .csv files before. My POIEditor for the iCN530 (not quite the same I know, but close enough) has (*.*) in the box, meaning that I can select any file, although only valid ones will be used. Try renaming the file and changing the .asc to .csv and see if that makes any difference. _________________ Tim |
Posted: Fri Jun 09, 2006 3:03 pm Post subject: |
thanks for your suggestion of changing file name to .csv it finally works.it seems with the new model 720 and i imagine 750 aswell its back to the old routine, open asc file in notepad delete first line lat and long and then rename as .csv file then poi editor finds files. thanks for you help tim |
Posted: Fri Jun 09, 2006 6:41 pm Post subject: |
Well they use the same app as the 530 (or so Navman told me) and that app has no trouble reading .asc files. _________________ Tim |
