Beep Occasional Visitor
Joined: Jun 04, 2004 Posts: 29 Location: Central Scotland
Posted: Mon Jun 05, 2006 11:29 pm Post subject: Destinator 6 TMC Question |
Recently bought Destinator 6 to replace Navigon Vn4 and am happy with the GPS side of things, however I have not been able to set up TMC (free version) to show any reports. Auto detect does not detect any channels but manual allows selection of a number of stations. Navigon uses Classic (ITIS) to receive broadcast but I suspect that Destinator uses Trafficmaster/RAC so in Central Scotland I suspect that is (Chrysalis) XFM Scotland. Anybody had any luck with TMC on Destinator 6?
Beep
PS This has also been posted on TMC forum but as yet no responses so thought I would try asking the same question here. |
Petekk Regular Visitor
Posted: Tue Jun 06, 2006 11:12 am Post subject: |
Prior to D6 release, I understood the situation to be that the standard version suported "free" TMC - i.e as is avaliable in some countries (not the UK), and that the new "traficsam" version would provide "pay TMC" i.e as avaliable as a premium service in Germany/France etc - or the only varient avaliable in the UK (i.e Itis and TM are both pay TMC services)
I have asked Destinator Support if TMC in the UK is supported by the standard version (i.,e without trafficsam) and received the following response.
Quote: | Destinator 6 supports also the standard version of TMC in the UK. You can purchase TrafficSam additionally and it will provide you with more detailled data about traffic jams as well as immediate information as soon as the traffic jams clear up. The advantage is that TrafficSam collects data from installed stations and not from i.e. radio stations. The fee will be roundabout 60? and this is for a lifetime. |
This now makes little sense? i.e Are both running from iTis / or TM & Itis combined? What are "installed stations and not from i.e local stations"? Any one else have some info., |
Posted: Tue Jun 06, 2006 3:36 pm Post subject: |
New reply from Destinator:
Quote: | Destinator 6 is available without Traffic Sam as well. The standart TMC is dependently to the free TMC Radio Stations which are currently not available in UK. You have to contact the www.trafficmaster.co.uk to get TMC messages in UK.
Do not hesitate to conctact us in case of further questions.
I suspect that the left hand doesnt know what the right hand is doing.
It seems that you need the Trafficsam version for the UK!!! Which does not yet appear to have a release date!!!! |
Posted: Tue Jun 06, 2006 11:11 pm Post subject: |
Thanks Petekk. As you were posting the second response from Destinator I was receiving the same reply, almost word for word, suggesting I contact Trafficmaster. I will post back any more details I receive. |
chippie_w Occasional Visitor
Posted: Tue Jun 13, 2006 1:56 pm Post subject: |
I received Navigator 6 yesterday and installed it on my Eten G500 which has inbuilt GPS & TMC receiver.
Went into the setup and set both GPS & TMC to receive on port 4 speed 38400. TMC set to autoscan
GPS locked on but TMC scanning FM channels but no input.
Then i remember reading somewhere that you have to plug your earphones in to act as an aerial.
Voila starting receiving Traffic reports.
These will be the same as you receive via RDS, not as many or updated live like Traffic Master, but its better than nothing and free!! :D
Regards
Chippy |
Posted: Thu Jun 22, 2006 12:45 am Post subject: |
what country are you in?
Is this the standard or the trafficsam version? |
ysurya Occasional Visitor
Posted: Fri Jul 14, 2006 10:51 pm Post subject: |
I have just upgraded my DPN5 to D6. The TMC was working perfectly well in DPN5. However, when I installed D6, it does not show any TMC option. I did select the TMC option during installation.
Can anyone advise me any possible solution.
Thanks |
TheRock Regular Visitor
Posted: Fri Jul 14, 2006 11:22 pm Post subject: |
ysurya
copy the tmc.cab from C:\DestinatorApps\Installer\Console\2577\WM5\TMC or C:\DestinatorApps\Installer\Console\2577\PPC2003\TMC on your PDA and execute it.
If you have on TMC options within D6 look in Destinator.ini and set your options with the editor. _________________ D7
loox n500 |
Posted: Sun Jul 16, 2006 3:31 pm Post subject: |
thanks TheRock
I tried your suggested method and its done. However, in the TMC menu, it only gives two options, i.e. 1) search - automatic / manual, and 2) avoid - automatic / manual. It does not ask for the radius, message types, etc. |
Posted: Sun Jul 16, 2006 7:42 pm Post subject: |
ysurya wrote: | thanks TheRock
They removed this options in D6 from the menu, cause it confused to many users.
You still can set them in the destinator.ini _________________ D7
loox n500 |
Posted: Sun Jul 16, 2006 10:56 pm Post subject: |
Thanks for your help TheRock
I have done the required settings in the ini file
bubbah Occasional Visitor
Posted: Tue Jan 12, 2010 2:09 am Post subject: help with gps settings on my fone |
I have version 9 of destinator that installs fine on my motosurf a3100 winMobile6.1 phone and accepts USA and EU maps with aplomb, however I am flummoxed how to use it to turn on and use the inboard GPS radio on my device. Any ideas ?? Google Maps works fine and sets com0 4800 ...do I need to set up some other way? If I do, will it mess up google maps or does it accept several specs?
---TIA !! |
Posted: Tue Jan 12, 2010 2:11 am Post subject: |
MORE DETAILS, there is an application in the phone settings titled 'external gps' that has settings IN THE FIRST TAB "PROGRAMS" for GPS PROGRAM PORT which is the "port programs use to obtain GPS data" with choices com 0-9 or GPD 1-9 (I don't know what GPD is). Since there is a SECOND TAB "HARDWARE" which has NONE selected and Baud rate 4800 which "specifies the hardware port to which the GPS device is connected" and finally ACCESS TAB only having a checkbox to "manage GPS automatically" saying this allows multiple programs to obtain GPS data simultaneously. ...what do I need to get the destinator app to "see" the GPS?? Google maps (as well as Bing and other stuff) have a "turn on GPS radio" item in the menus ...do I need to tell the GPS to turn on? I tried turning on in google maps and running destinator9 simultaneously...no joy! hellllp !! |
