BrianA Regular Visitor
![](modules/Forums/images/avatars/gallery/lighthouse.jpg)
Joined: Nov 22, 2003 Posts: 91 Location: Washington, UK
Posted: Sun Jun 04, 2006 2:37 pm Post subject: Jasjar + BT doesn't work in flight mode ... |
My HTC Universal / Jasjar (with TomTom) will connect to my BT GPS OK, provided I have the phone on (ie the Jasjar isn't in flight mode).
The TT website FAQ says this isn't a TT problem but happens with some PDAs where the BT won't work if the phone isn't on. Can anyone confirm a) if the Jasjar is one of these and b) if theres any workaround?
Cheers _________________ Brian Abbott
Go 520 + Navcore 8
(was a happy PDA user until TT stopped updating the software) |
7andy Regular Visitor
Posted: Sun Jun 04, 2006 2:43 pm Post subject: |
AFAICR - flight mode turns off all the wireless transmitters on the PDA - including Bluetooth. This is to prevent interference with the aircraft's electrical systems.
Cheers, 7&Y |
alix776 Pocket GPS Moderator
Posted: Sun Jun 04, 2006 2:57 pm Post subject: |
have you gone in to the coms manager and turned bluetooth on _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
lbendlin Pocket GPS Staff
Posted: Sun Jun 04, 2006 3:37 pm Post subject: |
This IS a TomTom issue, no matter what they try to tell you otherwise. TomTom have confused "flight mode" with "Bluetooth off". So even if you swithc BT on, and keep the radio off, TomTom will still refuse to work.
On WM2003 machines you can workaround by connecting to "other NMEA GPS" rather than to "other BT" but on the Exec (WM5) this workaround no longer works around... What you can do is switch the GSM radio on, start TomTom, and then switch the GSM radio off again. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jun 05, 2006 3:32 pm Post subject: |
lbendlin wrote: | This IS a TomTom issue, no matter what they try to tell you otherwise. TomTom have confused "flight mode" with "Bluetooth off". So even if you swithc BT on, and keep the radio off, TomTom will still refuse to work.
On WM2003 machines you can workaround by connecting to "other NMEA GPS" rather than to "other BT" but on the Exec (WM5) this workaround no longer works around... What you can do is switch the GSM radio on, start TomTom, and then switch the GSM radio off again. |
Thanks Lutz. I'll do what you suggested (and keep my fingers X that TT fix it on TTN6 ...) _________________ Brian Abbott
Go 520 + Navcore 8
