johnwille Occasional Visitor
Posted: Thu Jun 01, 2006 8:16 pm Post subject: POI Capture - on TOM TOM 700 |
Hi, Can anyone help? I am running a Tom Tom 700 and having trouble installing POIcapture. I have followed the installation instructions on the site but it still does not display the Capture Icon. I have uploaded the 5.202 system software succesfully. Please help
John |
Oldboy Pocket GPS Moderator
Posted: Thu Jun 01, 2006 10:23 pm Post subject: |
Is there a reason why you are using 5.202?
I ask because the later versions of POICapture are better.
The loading instructions are nearly the same for each version.
Can you give some idea of what you've done - which files you've loaded where, etc.
It saves having to guess, and then getting it wrong.;) _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Thu Jun 01, 2006 11:37 pm Post subject: |
I had version 5.201 installed on the Tom Tom 700 but following instructions on thr speed camera database you need 5.202 for POIcapture to work. i have two subfolders in a folder named "GO" on the main directory of he TOM TOM. The subfolders are :"POI Captute" which has files Dixon, POI Capture and another subfolder Icons and SdkRegistry which contains files POICapture, POICapture.cap, tomtom.mnu which was renamed as such from tomtom.700.mnu
Hope that helps |
Posted: Fri Jun 02, 2006 6:35 am Post subject: |
johnwille wrote: | i have two subfolders in a folder named "GO" on the main directory of he TOM TOM. |
The 2 Folders, POICapture and SdkRegistry should be in the Root of the SD Card, at the same level as the Map Folder. _________________ Richard
Posted: Fri Jun 02, 2006 7:32 pm Post subject: |
Thanks, I have now uploaded 5.404 as well and it seems all to be working.
Thank you
John |
