Pocket GPS World :: View topic - tomtom 5 gps help
tomtom 5 gps help
gpsmad
PostPosted: Fri May 26, 2006 10:42 am    Post subject: tomtom 5 gps help Reply with quote
i have a xdalli and xdall
i have installed tomtom 5 on both using same setup however i can only get the xdalli to connect to my gps receivers.
no matter what com port i pick on the xdall tomtom only reports no gps device.
has anyone else come accross this problem and is there a fix.
xda
PostPosted: Fri May 26, 2006 11:20 am    Post subject: Reply with quote
It would help if you told us what type of and which make of GPS you are trying to connect to. Is it wired or Bluetooth?
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
wazzzzupmate
PostPosted: Fri May 26, 2006 11:42 am    Post subject: Reply with quote
Is this anything to do with installing the same software on 2 devices? Does this refer to two different sotware items, i.e. two separately purchased TT5 software packages or are you tring to setp the same software on two devices?
alix776
PostPosted: Fri May 26, 2006 12:26 pm    Post subject: Reply with quote
the xda 2 uses a different bluetooth stack than the xda2i have a serch for pocket bluetooth tools I can't post the link at the moment due to being away in scotland on holiday but if noones posted it by the time I get back then ill put the link up the bt tools will change the com port to com 7 if memory serves correct
device Lumia 950 xl
PostPosted: Fri May 26, 2006 3:59 pm    Post subject: Reply with quote
Have a look at http://bluetooth.i-networx.de/index_e.html the download is avail from this page, its by far the easiest way to get a BT GPS working on the XDAII. Mike
xda
PostPosted: Sat May 27, 2006 2:00 am    Post subject: Reply with quote
If it any help my XDAII is using Com 5 with the BT-338
Graham.
Nokia 925 Windows 8
22.071 (03 Jul 24)
