Pocket GPS World :: View topic - Using a TomTom Go in the USA
spawn_e_git
PostPosted: Wed May 17, 2006 4:39 pm    Post subject: Using a TomTom Go in the USA Reply with quote
Hello.
I'm travelling to the USA next week and I am intending to buy the maps from the TomTom website.
Do I need to do anything to the unit except install the maps to make it work in the US? For example, the sat settings etc will be the same?
Also, I do not use my TT that much but when I do use it, it takes about 8-10 minutes to find a sat signal, is this normal?
lbendlin
PostPosted: Wed May 17, 2006 7:08 pm    Post subject: Reply with quote
The maps are all you need.
When you step out of the plane, allow some more time for an initial fix. Subsequent fixes will be quicker.
The same is true if you don't use the device for a while. That behavior is normal.
Lutz
TomTom/TeleAtlas NAVTEQ
Tumbleweed
PostPosted: Wed May 17, 2006 9:36 pm    Post subject: Reply with quote
IT might be better if he goes for the 'factory settings' (or whatever its called) option that way he can tellit he is in the US so fix should be a lot quicker. Otherwise he could be lost on US192 and deep intp the everglades before he gets his fix!
tgold
PostPosted: Wed May 17, 2006 10:34 pm    Post subject: Re: Using a TomTom Go in the USA Reply with quote
spawn_e_git wrote:
Hello.
Everything is the same except the clock time offset if you use the displayed time and ETA. One more suggestion is to select an American voice, as that may help to remind you to drive on the right.
Have a great trip.
Tony (with his TomTom GO now in Key West FL)
spawn_e_git
PostPosted: Wed May 17, 2006 11:51 pm    Post subject: Reply with quote
Thanks :D
