Pocket GPS World :: View topic - IPAQ 6340 and Medion MDPPC250 Problem
Bappsack
PostPosted: Sat Apr 22, 2006 8:34 am    Post subject: IPAQ 6340 and Medion MDPPC250 Problem Reply with quote
Hi all together,
I hope anyone can help me. I have installed the newest dirver (1.33) on both PDAs for my GlobalSat SD-502 SDIO GPS Receiver. GPS is working, with GPSInfo I see a lot of satelites assigned to com0 GPSUART. But none of my programms like GPSFis or Vitesse Limit let me choose com0.
The next problen on both PDAs is, I cannot copy my Navigationsoftware (Navigon MN 4.2), e.g. maps to the sd-card. Smaller Files are copied fine to the card, but two files greater than 90 MB not. Every time I tried this ~30% is copied and then copying is starting from the beginning.
Any suggestions would be appreciated. I have an open Ticket at Globalsat, they suppose to deinstall the driver and then a new install, but this dosnt help.
br
Christian Franke
lbendlin
PostPosted: Sun Apr 23, 2006 3:22 am    Post subject: Reply with quote
Can't you insert that card into a PC and copy the files directly? Does it need drivers for the memory part?
Lutz
TomTom/TeleAtlas NAVTEQ
Bappsack
PostPosted: Sun Apr 23, 2006 8:36 am    Post subject: its working, problem solved Reply with quote
Hi Lutz,
yes you need a driver, ut actually the problem with copying files greater than 90MB is solved. I think I am a little bit to impatient and I have too wait a longer time.
br
christian
22.062 (12 Jun 24)
