ghost181 Occasional Visitor
Joined: Sep 25, 2005 Posts: 34 Location: stoke-on-trent, staffs
Posted: Sat Apr 15, 2006 2:49 am Post subject: TT5 back up on sd card |
I have been reading a post about back up tt5 on the sd card. Mikealder spoke about copying 2 .cab files on to the sd card in case the battery ran low. can any one tell me were the 2 .cab files are located as I have searched the sd card and cannot find them.
any help would be great
My system is
pda running windows mobile 2003 se
TT5.21 GB maps
regards _________________ Garmin 1310
map ver 2010:10
GB maps |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sat Apr 15, 2006 8:42 am Post subject: |
I think you find them on the Installation CD of the 7 CD Navigator CD Set. _________________ Richard
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Apr 15, 2006 9:57 am Post subject: |
You need to extract them from the installer when it is running, the folder you need to look at on the PC is C:\Documents and Settings\user\local settings\Temp\WZSE0.TMP\nvapp\app in here will be either a set of four CAB files (gps.cab_PIMAddin.cab_ttn.cab_wzd.cab) or more recently two files (tt.cab_tomtom.cab).
Have a read of this link to find out whats involved http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=27097&highlight=cab+files
Once you have the CAB files (the old installer created four files, more recently you only need two).
Copy the files to a known location on you PC, in Windows Explorer right click each CAB file select Properties and make sure they are set too read only, otherwise they will self destruct when you run them, and you need to do this all over again.
Copy the CAB files to your SD card in a known folder and you can re-install the application in seconds when you loose everything. I use this method, but prefer to rely on Sprite back-up which puts everything back on in one go - Mike |
Posted: Sat Apr 15, 2006 1:19 pm Post subject: tom tom 5 back up on sd card |
well first thanks for the prompt reply and email from forum/pocketsgps very impresed with the prompt reply
in reply to the message from oldboy I purchased a genuine copy of tom tom 5 GB maps which only has 1 cd
I have found the .cab files in the folder "2577" with in the tom tom program and copyed (there are 4 .cab files)
gps.cab
ttn.cab
wzd.cab
pimaddin.cab
to a new folder and made them read only my final quirey (i hope) which one(s) do I need to activate to put tom tom back on my pcc if ever I let the battery go so low and have to reinstall tom tom
as all way thanks for the help _________________ Garmin 1310
map ver 2010:10
GB maps |
Robin2 Lifetime Member
Posted: Sat Apr 15, 2006 5:31 pm Post subject: |
It's well worth while investing in a copy of Sprite Backup. Using this you can back up your PDA onto a storage card at regular intervals, opting to keep the latest two backups on the card. It is then a simple matter to restore the PDA to an earlier state, and you can do it when you are away from the PC. The backup restores everything on the PDA, not just your GPS software
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Mon Apr 17, 2006 12:38 am Post subject: |
Hi ghost181,
I agree with Robin 2. Sprite Backup is worth its weight in gold. You could be in the middle of France on a rainy night, attempt to turn on your PDA and for some reason find that you have lost everything. No problem. Sprite Backup will restore everything to the same state as when the backup was made. The programmes, Bluetooth settings, everything back as it was. Its brilliant. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
