Pocket GPS World :: View topic - TomTom 300
TomTom 300
rory
PostPosted: Fri Apr 07, 2006 8:31 pm    Post subject: TomTom 300 Reply with quote
I have tried to install the cameras database (all three options). When the files are loaded on to the card and the device reboots I get an error message showing 'No GPS device'.
If I remove the files the TomTom works ok.
What am I doing wrong!!!!!
Rory
PostPosted: Fri Apr 07, 2006 9:06 pm    Post subject: Reply with quote
How are you loading them on the Card?
What are you actually Loading on to the card, and where are you putting it?
This will help us to give you a better answer.;)
rory
PostPosted: Sat Apr 08, 2006 8:45 pm    Post subject: Reply with quote
Thanks for the reply.
I have copied the OV2 and BMP files supplied in the zip file. I have copied the files and pasted them into great_britain-map folder on the card.
I have used the standard 128mb card as well as a 256mb card. Both work fine without the OV2 and BMP files.
rory
PostPosted: Sat Apr 08, 2006 8:50 pm    Post subject: Reply with quote
Which Device are you using?
rory
PostPosted: Sat Apr 08, 2006 8:57 pm    Post subject: Reply with quote
I am using a TomTom 300 still using version 5.00.
PostPosted: Sat Apr 08, 2006 11:13 pm    Post subject: Reply with quote
Are you sure about the message? Does it say No Valid GPS Signal?
I can't see why adding a .ov2 and .bmp Files should stop the software running, as they are just data files that the software can read.
Does it do it if you only load one .ov2 File?
Another suggestion is to Upgrade to 5.420 or 5.440 and see if this makes a difference.
Tumbleweed
PostPosted: Sun Apr 09, 2006 9:26 pm    Post subject: Re: TomTom 300 Reply with quote
rory wrote:
Rory
When I had this it was insufficient space on my SD card, but it was also necessary to do a reset to recover.
You could try what I did, this worked for me, might just have been a coincidence but .....
...using the 256 Mb card i think you said you had, select 'factory reset' or similar.
Then reboot.
Then check the time is OK (Mine was out by 12 hours aftera crash and that may also have caused the problem)
If you need to reset the time, do so, then reset the TT and check its the proper time afterwards.
Hopefully that will fix it.
Tw
22.064 (26 Jun 24)
