Pocket GPS World :: View topic - No GPS device.
No GPS device.
muhdatif
PostPosted: Wed Mar 29, 2006 5:14 pm    Post subject: No GPS device. Reply with quote
hi,
i m trying out all possibility to run my GPS system which is consist of
bluetooth GPS device, Dell Axim X30, Tom Tom 5. But tom tom keep showing me the GPS status as "No GPS device." which is installed on my DELL X30.
i have tired to configure all options available under bluetooth connection.
Could any1 please help me out.
i m now about to pulling out my hair ...
Looking forward some positive solutions
Many Thanks.
gamichea
PostPosted: Wed Mar 29, 2006 9:15 pm    Post subject: Reply with quote
Have you successfully paired the gps device and the Axim and are you using a TomTom gps device?
If the gps and Axim are paired and you are not using a TomTom gps the usual solution to this issue is not to start TT until the gps has acquired satellites. This works for me.
You need to have configured TT for "other bluetooth gps" as well ("other" meaning not TomTom).
Nexus 7 (2013) & Nexus 4/Sygic/CamerAlert
In Brodit passive mounts on Moveclip/Proclip
peterc10
PostPosted: Thu Mar 30, 2006 10:15 am    Post subject: Reply with quote
You will find that often "other bluetooth" will not work, despite you using an "other BT" receiver. In TT Change Preferences, choose Show GPS Status then Configure. Try choosing "Other NMEA" rather than "Other bluetooth". You may then need to experiment with Com Port and BAUD rate (on next screen). Leave the system for a while with a clear view of the sky and see if that works.
Peter
HTC Sensation
Copilot for USA
alix776
PostPosted: Thu Mar 30, 2006 11:06 am    Post subject: Reply with quote
peter that was fixed in the lastest versions other bt now works fine muhdatif tomtom usually displays the no gps device for a few seconds its not instant is the dell running wm5 or wm2003se there is a differnce in setting up the bt gps between the windows mobile versions
for wm05 pair the gps then in the bt manager select comports then select new outgoing port then select the device and set a comport of com0 ok then start tomtom go to the gps set up and select other bt gps tap ok then select com 0 then tap done give is few seconds and the dell should pick up the gps
if its wm2003 then pair the device start tomtom select other bt gps then ok then select the com port for your device
device Lumia 950 xl
muhdatif
PostPosted: Thu Mar 30, 2006 11:40 am    Post subject: Reply with quote
Yahooooo......it works now :D
Thanks a lot guys, You are Guru Idea
i chose the "Other Cable NMEA GPS" option and tried different baud rate and it worked.
I m soo pleased now to see it working Smile
once again Thanks.
Cheers!
Atif
peterc10
PostPosted: Fri Mar 31, 2006 10:39 am    Post subject: Reply with quote
By the sound of his reply he does not have the latest version.
Peter
HTC Sensation
Copilot for USA
22.094 (25 Sep 24)
