paul1000 Occasional Visitor
Posted: Mon Mar 27, 2006 10:02 pm Post subject: navman 520 |
Could any one help i have a navman icn520 and cant seem to down load any speed cams could any one help thanks what it tells me is when i have down loaded it it says unknown file format which means nothing to me any help would me good |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon Mar 27, 2006 10:13 pm Post subject: |
OK, which file(s) have you downloaded? Have you specified Navman as your SatNav system? _________________ Tim |
Posted: Mon Mar 27, 2006 10:33 pm Post subject: |
Tim Buxton wrote: | OK, which file(s) have you downloaded? Have you specified Navman as your SatNav system? |
i have down loaded gatso,mobile and specifield navman as my system it down loads in about 1 sec and will not open on any file have tried it about 3 times and opened it and saved it to differnt files and still no good i am using windows xp to download it to thanks paul |
Posted: Mon Mar 27, 2006 10:40 pm Post subject: |
Then you should have a couple of .zip files wherever you downloaded them. WinXP should be able to extract the .asc files. _________________ Tim |
Posted: Mon Mar 27, 2006 10:50 pm Post subject: |
Tim Buxton wrote: | Then you should have a couple of .zip files wherever you downloaded them. WinXP should be able to extract the .asc files. |
thanks found the zip files but still will not open just says unknowen format it will open some of the file like the pic of speed cams and thats all have tryed to move them to other files and open them but no good .poss problem with computer then . |
Posted: Mon Mar 27, 2006 11:11 pm Post subject: |
Could be. Do you have WinZIP installed? Try deleting what you have and then redownloading. You should end up with .asc files which will import into the Navman with no editing. The previous .csv files did require editing before being used. _________________ Tim |
Posted: Mon Mar 27, 2006 11:15 pm Post subject: |
Tim Buxton wrote: | Could be. Do you have WinZIP installed? Try deleting what you have and then redownloading. You should end up with .asc files which will import into the Navman with no editing. The previous .csv files did require editing before being used. |
thanks i will try that later. |
