mm90 Occasional Visitor
Posted: Fri Mar 17, 2006 2:25 pm Post subject: Frame rate drops with POI shown e.g. Speed Camera |
Guys,
Just got my Rikaline 6033 a few days ago and been playing around with TT5 quite a bit
Anyhow, I noticed severe frame rate reduction on my xda II mini running TT5.21 when POI are shown on the map, especially when the speed detectors locations are shown. Anybody experience similar symptom here?
Anything that could be done to increase the performance?
Thanks in advance.
Cheers. |
Posted: Fri Mar 17, 2006 2:34 pm Post subject: |
Welcome to the forum, instead of having the Enable POI options ticked for the cameras just use the Warn when near POI option instead, this will put the refresh rate back to a more normal display - Mike |
Posted: Fri Mar 17, 2006 2:39 pm Post subject: |
I figured the same thing this morning while driving to work (still playing with my TT ) I had turned off the POI but still getting the voice warning on the speed cameras. Is that the only way around? Is it not possible to 'tweak' it a bit for better display performance? |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Mar 17, 2006 3:51 pm Post subject: |
Make sure you have no programs running in the background and keep the POI's switched off. Also try with Street names on and off to see if there is a difference. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
StevenGourlay Frequent Visitor
Posted: Fri Mar 24, 2006 6:51 pm Post subject: |
You will see that your PDA has a lower CPU than most of the newer models which are about 400Mhz. If my memory serves me correctly its a 201Mhz CPU on the XDA MINI S as they lowered the CPU to increase battery life etc. _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
Posted: Fri Mar 24, 2006 7:07 pm Post subject: |
My PDA is the first xdaII mini (not the mini-S) which is based on Intel PXA272 416Mhz chip. Anyway, I don't believe the processor is at fault. The more pertinent issue here maybe is the amount of free built-in storage & program memory. I normally have between 6-11MB free only. Wondering how much you guys normally have? |
Posted: Fri Mar 24, 2006 11:46 pm Post subject: |
Quote: | I normally have between 6-11MB free only. |
Is this with or without TomTom running? _________________ Formerly known as Lost_Property
Posted: Sat Mar 25, 2006 5:11 pm Post subject: |
That's without TOMTOM running. |
Posted: Sat Mar 25, 2006 5:18 pm Post subject: |
Is this an O2 device per chance? and if so has the device been configured to load the O2 "Active Interface" onto the desktop? the reason I ask is that I have experianced serious problems when this is loaded I must add that these problems were on other XDA devices and not the one you are experiancing problems with, but it might be worth considering if it is loaded, the unfortunate part is that to remove it requires a hard reset - Mike |
Posted: Sat Mar 25, 2006 5:26 pm Post subject: |
Yes, this is an O2 device. However, I've never encountered any O2 "Active Interface" before. When you say 'desktop', did you mean the 'Today' page? |
The reason I asked
Quote: | Is this with or without TomTom running?
| Is because my Mio168 Shows 24.75MB Program and 26.17MB Storage Free, when TomTom not running. Your reading did seem low. Hopefully mikealder's sugestion will do the trick. _________________ Formerly known as Lost_Property
Posted: Sat Mar 25, 2006 5:31 pm Post subject: |
mm90 wrote: | Yes, this is an O2 device. However, I've never encountered any O2 "Active Interface" before. When you say 'desktop', did you mean the 'Today' page? | Its not part of the Today page, it actually adds a load of internet/ wap related shortcuts to the main screen (the one that has the Start button top LH), as you have not encountered Active Interface before it probably (hopefully) isn't loaded to your device, as I said earlier this was on a different unit but thought O2 might have put it on XDAII mini - disregard this as a possible problem then, anyone anymore ideas? - Mike |
Posted: Sat Mar 25, 2006 5:53 pm Post subject: |
Quote: | I normally have between 6-11MB free only |
Just checked mine again and it has a total of 62.82 main memory and even then my screen slows if I have POI's enabled.
With TomTom off mine shows 6.98MB Program Memory In use and 4.9MB Storage Memory In use.
Do you know the maximum available memory on your device?
Either there is insufficient memory on your device, something is running in the background or maybe something gone wrong on the main board.
Maybe a hard reset and re-install. Only install the minimum you require and see how it goes. If it then runs OK, add other bits and bobs, one at a time, to see if there are any detrimental effects. It may help you pinpoint the problem. _________________ Formerly known as Lost_Property
ellcheepo Occasional Visitor
Posted: Fri Mar 31, 2006 4:20 pm Post subject: |
Hi guys, Just thought I would add my two cents worth the XDA mini in the same phone as the Imate Jam and as such only has 64md memory for device storage and program running. So that works out as 32mb each way.
My suggestion it so move all of your program storage to a memory card and thus increase the amount of memory running programs can use. I use to have a Jam and that was how I got it to perform better. |
