Pocket GPS World :: View topic - MEDION MDPNA200S MD95900
MurrayMint
PostPosted: Wed Mar 15, 2006 12:27 pm    Post subject: MEDION MDPNA200S MD95900 Reply with quote
I think my battery went flat on my PNA the other day and it managed to re-set its self back to factory settings, all was ok as it re-installed Navigon and all worked fine.
Then i wanted to install POI Warner to add the speed camera database but could not get the PNA to connect to activesync or even be seen by the computer. I have reset the unit a few times to see if it springs back into life but have had no joy.
Has anyone had this problem too, any thoughts would be great.
Cheers, Ben. Sad
yodaofborg
PostPosted: Fri Apr 07, 2006 1:15 pm    Post subject: Reply with quote
yes
it does register eventually with active synch as long as you connect the cable then turn the unit on
sometime i have to do this a few time befor eit appears
also put the speed cam stuff in the Warner poi folder (in another folder called POI or similar) not the map folder
22.071 (03 Jul 24)
