Pocket GPS World :: View topic - Any chance I can "merge" the files into speed limi
jkljkl6
PostPosted: Tue Mar 07, 2006 10:47 pm    Post subject: Any chance I can "merge" the files into speed limi Reply with quote
I'm running out of available POI's on my TT software v5.4xxx and would like to have JUST the 30, 40, 50, 60, 70, mobile and variable speed cameras loaded. Any ideas how I go about this.
While I'm here, the TomTom pre-loaded POIs (and some other downloaded ones) don't seem to be editable, is there anyway that I can change this to make them editable e.g. add to them or delete incorrect entries?
Oldboy
PostPosted: Wed Mar 08, 2006 7:52 am    Post subject: Re: Any chance I can "merge" the files into speed Reply with quote
You can use POIEdit or POIConverter to merge OV2 Files. You will need to use a common BMP File to match the new OV2 Filenames.
It's a legal grey area, as it is part of the Map Data supplied by TeleAtlas. Someone reported that they could edit it with the latest version of POIEdit!
Also have a look at http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=135604
Personally I just use custom ones.
PostPosted: Wed Mar 08, 2006 2:46 pm    Post subject: Re: Any chance I can "merge" the files into speed Reply with quote
Do you actually want to merge files? If so then Oldboy's links are what you need.
However. It sounds like you may be happy with a combination of some of the speed-zoned files and some of the combined files from the "camera types" download.
For example, you could install:
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_redlight.ov2
...which reduces the categories used from 23 down to 12.
Even easier, if you really don't want the redlight, specs etc. warnings, just leave those filesjust some of the camera types, in which case just leave those files off.
tanda
PostPosted: Thu Mar 09, 2006 5:29 pm    Post subject: Reply with quote
Hi Everyone, I only use the single file, all cameras, that would save even more categories. Personally I think If a speed camera is up ahead, and your Sat Nav warns you of A CAMERA, and you slow down to the limit, if you are over it. It doesnt realy matter what type it is. So why do you guys download all these categories, what is the advantage/disadvantage of just a single categories, against many categories?
Audi A3 Sline sat nav
jkljkl6
PostPosted: Thu Mar 09, 2006 5:51 pm    Post subject: Reply with quote
Firstly Thanks OldBoy, POI Edit has helped, I merged the some of the other POI's I had which freed up the room for a selection of the various files. Any idea how I delete duplicate entries, other than selecting each file and deleting them individually (I now have over 11,000 pubs listed)??
For anyone's interest the files I use now are:
pocketgps_uk_gatso_ - Full range of limits...
pocketgps_uk_specs.ov2 - again over the full range
In answer to Tanda's question there's a few reasons why I like the limits mentioned:
If I'm in an area I don't know (especially in towns) the speed limits can go up and down like a yoyo.
I also like the Specs cameras with the speed limit as these you have to stay within the limit for a period of time (as you are measured over a distance).
Temp cameras tend to have the speed limit sign posted HUGELY all over the place so there's no excuse for not knowing.
I also have a different warning sound for mobiles as this entails police vans watching out for a multitude of sins, not just speeding (no driving with your hands behind your head and your feet out the window then?).
Hope this explains things?
Oldboy
PostPosted: Thu Mar 09, 2006 8:29 pm    Post subject: Reply with quote
You could try a program called POI Manager from Oldie's website. It works for me.
http://rjdavies.users.btopenworld.com/POIManager_Pro_v1104.zip
22.063 (19 Jun 24)
