silverdales Occasional Visitor
Posted: Wed Mar 08, 2006 9:35 pm Post subject: New Map |
Hello
I had my TT1 now for a while, when I first opened it all up, it never asked for the activiation code for the GB map- it justr worked!
I just bought the western europe map from tom tom and again it just works - when and why/how will I need to use that plastic card with the serial numbers on it?
Cheers |
linrew Regular Visitor
![](modules/Forums/images/avatars/11577807844173139197d8.jpg)
Posted: Wed Mar 08, 2006 9:51 pm Post subject: |
hi
you will probably need it when doing map updates
and you will definatly need it if your tomtom breaks and you replace it with a new one
whatever you do DONT loose the card as it will cost you the price of the new maps to replace it
if you are ever asked for an activation code by the tomtom then goto www.ttcode.com and follow the instructions
ps make sure you make a backup copy of the sd card
linrew |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Thu Mar 09, 2006 1:43 am Post subject: |
The activation code won't change unless you change the map. You could get it now and write it down somewhere. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Thu Mar 09, 2006 4:21 am Post subject: |
is it therefore possible to install the same map on 2 devices assuming that one had a blank sd card to copy the data on to? |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Thu Mar 09, 2006 8:11 am Post subject: |
silverdales wrote: | is it therefore possible to install the same map on 2 devices assuming that one had a blank sd card to copy the data on to? |
It's certainly possible, but breaks the EULA which you agreed to when you bought the Product.;)
You could also run out of activations very quickly. _________________ Richard
Posted: Thu Mar 09, 2006 9:06 pm Post subject: |
but I have never used any activations..?
When and at what point will it ask me do you think?
Is it random or just when I update the map, after buying the map how long do I get updates for anyway? |
