Pocket GPS World :: View topic - Sound
Sound
simondeo
PostPosted: Mon Jan 16, 2006 3:17 pm    Post subject: Sound Reply with quote
Have lost the sound on my tomtom 300,gps works fine,
Just no direction prompts,checked settings all ok any ideas.
Privateer
PostPosted: Mon Jan 16, 2006 6:29 pm    Post subject: Reply with quote
Hi simondeo,
If you tap the bottom left hand side of the screen (the bit that gives you distance to next instruction), i.e. below the navigation "map" part of the screen, you should get a "sound volume" bar.
Is your volume set to 0%, i.e. is the slider on the left hand side?
Have you set the slider to 100%, i.e. to the right hand side?
Robert.
Garmin Camper 770 LMT-D
PostPosted: Mon Jan 16, 2006 8:00 pm    Post subject: Reply with quote
Assuming volume is up and not muted (in preferences), have you tried going to "Change voice..." and seeing if you can hear anything when you press the "Test" button?
simondeo
PostPosted: Mon Jan 16, 2006 8:41 pm    Post subject: Reply with quote
Tried that as well,changed voice over and iested nothing,also moved the slider bar up and down and set it at 100%,i then press done it goes back to the map and in the top right hand corner says volume 100% but theirs still nothing.
RKC
PostPosted: Sun Mar 19, 2006 8:52 pm    Post subject: Reply with quote
Simondeo,
I have the same problem on my Tom Tom Go Classic. Did you solve this problem? If so, what did you do to get the sound back?
Tumbleweed
PostPosted: Mon Mar 20, 2006 12:30 am    Post subject: Reply with quote
RKC wrote:
Simondeo,
Have either of you tried a reset?
Tw
proguk
PostPosted: Mon Mar 20, 2006 2:13 am    Post subject: Re: Sound Reply with quote
What happens if you try to set up an audible warning for a POI? Do you hear the beeps/bells etc. when you 'test' them?
22.071 (03 Jul 24)
