Pocket GPS World :: View topic - HP rz1710
HP rz1710
herbieburt
PostPosted: Tue Feb 28, 2006 2:31 pm    Post subject: HP rz1710 Reply with quote
operating a HP rz1710 in a TomTom in car cradle running TT Navigator software been fine for 12 months suddenly it won't receive sat signals i noticed that the green led light was no longer flashing on the antenna i took it apart checked the wiring and the RJ11 connector plug for continuity seems ok -is it a software issue or an electronic fault with the PDA,cradle or antenna any ideas anyone?......i'm lost without it!!!
randyshooter
PostPosted: Tue Feb 28, 2006 6:25 pm    Post subject: Reply with quote
hi i am running exact same set up and have recently had power interuption problems which has led to green light going out and losing sats. a stupid question but have you checked the power lead?
herbieburt
PostPosted: Thu Mar 02, 2006 11:52 am    Post subject: rz1710 antenna problems Reply with quote
yes the antenna lead has been checked by taking the casing apart and testing from the RJ11 plug to the soldered terminals(although not sure if there is a fuse inside the casing? couldnt see one)also the power to the cradle is continuous as the pda is charging
herbieburt
PostPosted: Thu Mar 02, 2006 11:12 pm    Post subject: Reply with quote
yes the cables have been checked including the rj11 plug
22.071 (03 Jul 24)
