Skidog Occasional Visitor
Joined: 05/09/2003 00:41:29 Posts: 3 Location: United States
Posted: Sun Sep 14, 2003 8:04 am Post subject: Unable to open GPS port com 4; port |
I have an Ipaq 3650 most current rom 1.88, navman 3450 sp2 installed and a 256 cf card. I finally got the Navman to recognize the sleeve but cannot get it to use a com port. Here is the error:
Unable to open GPS Port COM4; port has already been opened by anotehr application.
I don't have any additional software installed, I have the following Navman related software installed:
Navman driver (3.1.6)
Navman GPS Info 1.3 (3.1.6)
Navman SmartST Professional sp2
I tried to delete both of the drivers one at a time but need them both.
Any help would be appreciated.
Thanks,
Mike |
gambitgander Regular Visitor
Joined: 17/10/2002 09:41:39 Posts: 111 Location: United Kingdom
Please soft reset and run only one GPS application at one time. ie, you cannot run GPS Info and Smart ST at the same time. |
Gambitgander,
I did as you suggested and I now have the error
"Failed to get NMEA data Sleeve Comms error Contact Navman support"
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
You may be selecting the wrong com port. If something else is using COM4, you may be using the GPS Sleeve on COM5 or COM6. |
I called navman and they decided I had a bad Navman. They are sending another unit out.
