Pocket GPS World :: View topic - ipaq 3850 and HI-305III problems
gui076
PostPosted: Thu Feb 09, 2006 8:03 pm    Post subject: ipaq 3850 and HI-305III problems Reply with quote
I have received my CF GPS today HI-305III. I have installed drivers and Haitest software. i plug it into the CF port via the expansion pack. I launch haitest software and i select com port 5 and 4800 bauds and then click on start GPS. There are no informations appears.
can you help me please ?
I have done a hard reset recently and i have just installed drivers and Haitest.
- Ipaq 3850 PPC 2002 ROM 1.15
- Expansion pack
- Hi-305III CF GPS
gui076
PostPosted: Fri Feb 10, 2006 3:52 pm    Post subject: probleme HI-305III et ipaq3800 SOLVED ! Reply with quote
I have solved my problem. When i plug the CF GPS and the message "No SD card detected" don't click on OK but just move the window. i have launched the GPS viewer program and it's working !!
I hope this will help anybody who have the same problems. :D
Configuration :
- ipaq 3850 PPC 2002
- Haicom HI-305III CF GPS
Guillaume
Tullinge
PostPosted: Sat Jul 08, 2006 5:54 am    Post subject: Haicom HI-305III GPS Receiver problems Reply with quote
I can confirm the problems with the subjected device:
When it arrived from retailer it did not install just by means of installing the drivers.
You also need to install the utility GPSinfo supplied on the disc.
Start the utility, do portscan to locate/identify the device.
Do "Coldstart" and start GPS. After this, you should be able to see the comunication with the GPS.
Close GPSinfo and start TT5. Now you should be able to use the GPS.
However, and this is quite important: If you have had your device unpowered for a couple of months you might run into the very same problem again, meaning TT5 will not be able to connect the the GPS.
The only way to solve the problem is to run GPSinfo and reinitiate the GPS.
Conclusionwise from this learning I have no other explanation to this than a built in (embedded in the GPS device) battery discharges after some time and drops the configuration data provided by the utility).
After you have got it working remember to do PDA backup ......
On the upside, once you got it working it is perfoming nicely and provides GPS tracking during difficult conditions (cities with high surrounding building, tunnels etc)
HW: HX4700, Hicom HI305-III, Transcend 4GB SD
SW: TT 5.21, Checkpoint 5.02
22.063 (19 Jun 24)
