woody82 Occasional Visitor
Posted: Mon Feb 06, 2006 6:43 pm Post subject: Speed cameras for tom tom one |
I have tried putting speed camera files on my tom tom but nothing happens. its on there but when i turn my Tom Tom on, it is normal, without any speed camera stuff on ther ...... help! |
alix776 Pocket GPS Moderator
Posted: Mon Feb 06, 2006 6:50 pm Post subject: |
you need to copy the camera files ie the .ov2 and .bmp files individiually to the map folder and then activate them to in the manage poi menu on the tomtom _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Feb 06, 2006 6:58 pm Post subject: |
which are the best files because there seems to be lots of different files. Is there a file with the full range of cameras on that i can download and can you tell me where it is please. sorry not very good at stuff like this |
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Mon Feb 06, 2006 7:01 pm Post subject: |
Hi woody82,
to the forum!
There are some guides that should be read (in the following order):
The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Garmin Camper 770 LMT-D |
Posted: Mon Feb 06, 2006 7:12 pm Post subject: |
sorry, what is the file name and what page is it on so i can download it. thanks |
Posted: Mon Feb 06, 2006 7:28 pm Post subject: |
done that and now there is not enough room on standard sd card that came with it. Can i delete anything off it? sorry to be a pain mate |
Oldboy Pocket GPS Moderator
Posted: Mon Feb 06, 2006 9:25 pm Post subject: |
You could try deleting any un-used Voices. Just one will make enough difference. _________________ Richard
