Pocket GPS World :: View topic - ?compatibility -pls help!! Hi204E and Hi-403BT (using viaM)
moggers
PostPosted: Mon Jan 16, 2006 12:36 am    Post subject: ?compatibility -pls help!! Hi204E and Hi-403BT (using viaM) Reply with quote
Hi there am a complete newbie to this sort of thing so do bear with me and i would greatly appreaciate some help eso if anyone has exp of this.
I have a Palm T5, A Hi-204E and a Hi-403BT, which I am trying to use with Via Michelin navigation system (v3.3).
I was wondering if there were any compatibility issues that i am not aware of or if there are any patch solution s that you might provide?
I have the problem that the pda only intermitantly connects with the BT device. I know its connected when the blue lights stays constant. I keep getting this message from the pda that it needs me to select a device, ie the connection cuts off. Consequently the gps very occasionally works and it has rendered my gps system fairly useless (as i am interupted every 1min to re-connect the bluetooth device). IT is getting to the stage where it is really annoying but i dont know what to do next!!
I wonder if you might help!
cheers ;D
Omer
PalmOne T5, Palm OS v5.4.2,
128MB sd + 1GB,
ViaMichelin 3.3 /Mapstore
GPS: Hiacom Hi-204E with Hi-403BT
22.064 (26 Jun 24)
