smithy38 Occasional Visitor
Posted: Sat Jan 14, 2006 6:25 pm Post subject: Which GPS Receiver should I buy? |
Hi, I'am a newcomer to satellite navigation. I have just purchased a XDA 2 and Tomtom Nav 5 software. Now I have an issue, which receiver should I buy? Bluetooth or wired and how many satellites do I need to track? Can anyone offer me some advice please? |
Posted: Sat Jan 14, 2006 7:41 pm Post subject: |
Welcome to the forum, the choise on the GPS unit depends on what you want to do with it and price, if its for nothing more than car based usage go for a wired unit (they are cheaper as well), if you want to use it for walking etc. then the versatility of a good bluetooth unit enters into its own - in either case I would sugest a SiRF III equipped based device, the Holux unit I use is incredible, aquiring fixes inside buildings etc. Very impresive (not that I would ever recomend setting one up inside that is) - Mike |
astrocompass Lifetime Member
Joined: Aug 15, 2005 Posts: 156 Location: Windsor, UK
Posted: Sat Jan 14, 2006 8:06 pm Post subject: |
Hi Smithy
MikeAlder wrote:
Quote: | if its for nothing more than car based usage go for a wired unit (they are cheaper as well), |
..depends whether you want trailing wires all over the place. That's how I started. Certainly cheaper but a lot messier.
MikeAlder wrote:
Quote: | in either case I would sugest a SiRF III equipped based device, the Holux unit I use is incredible, aquiring fixes inside buildings etc. |
Agreed. You might also want to consider a Globalsat BT338.
How many satellites? The minimum necessary to give you an accurate fix - half a dozen or so should do the job. Quantity doesn't equate to quality.
Oh, and welcome to the forums! _________________ Garmin 2360LT
iPaq 2210 TTN5.2 |
