Pocket GPS World :: View topic - Idiots Guide
Idiots Guide
forumhound
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Idiots Guide Reply with quote
I'm trying to find a site that includes an idiots guide to scanning maps for use in MM. Anybody know of one ??
Forumhound
Best thing is to talk to Mike here, he'll be able to put you straight as he's our topo scanning master!
forumhound
Thanks for that.. I'll have another bash at it myself, then contact him if I fail miserably..
Forumhound
PLEASE DONT ASK ME!!!
MM is not really designed for scanning and calibrating your own maps. I tried calibrating a couple of maps and failed. The latest software upgrade for Navigator has calibration built in, but again I was never able to get that to work properly.
Your best bet if you have a lot of maps you need to calibrate and use is to move to another software package that does support both the calibration and the use of multiple datums and projections. Examples are: Oziexplorer and Fugawi (not UK).
Oldie
There is a Technical Support bulletin covering self scanning of maps see here
I have successfully used a scanned map in an earlier version of Navigator, but I have not tried recently.
Oldie,
That was the document that I was working from, problem is that there is no easy facility to enter accurate information.
Did you find your map accurate? If you did you were lucky that the calibration routine used the same map projection as your scanned map.
With the latest release of Navigator it is supposed to be easier, but I still had difficulty calibrating.
At the end of the day Memory Map does not have the tools to calibrate maps properly. As I said in my earlier post Ozi or Fugawi are best for easy and reliable scanned map calibration. I have achieved very high precision calibration by being able to calibrate points that I have not visited before in both of these applications. Both in the UK and for Swiss and Italian maps which use different grid systems and map projections.
Oldie
MikeB,
I have just had a look at my scanned map. It was from one of my 1:25,000 scale OS maps, and a track taken from my Garmin eTrex Legend overlays on it quite well. The track is slightly different from that shown on the MM 1:50,000 scale map of the same area, but not by a constant amount.
I agree with you, it is not easy to do and I would not like to try other grid systems. Having said that I am thinking of taking a holiday in New Zealand - what are my chances of getting any detailed maps for my PC or PDA? At the moment I have the Garmin World Map, which is better than nothing (just).
Richard,
Well if you go over to the Yahoo OziExplorer group you may find some maps there.
You can find them at http://groups.yahoo.com/group/OziUsers-L/
Otherwise you could buy some paper maps and scan and calibrate them.
