Pocket GPS World :: View topic - Tom Tom One Help Please????
saabcarlsson
PostPosted: Sun Feb 26, 2006 6:27 pm    Post subject: Tom Tom One Help Please???? Reply with quote
My friend has just got a Tom Tom One and he needs to install Speed Camera software and Low Bridge as he is a truck driver. Can anyone help me please in how to do this????
alix776
PostPosted: Sun Feb 26, 2006 6:49 pm    Post subject: Reply with quote
the low bvridge height database is available from www.willow-house.co.uk instalation is the same as the speed cameras just copy the .ov2 and .bmp files to the map folder after opening the .ov2 folder
device Lumia 950 xl
Privateer
PostPosted: Mon Feb 27, 2006 2:49 pm    Post subject: Reply with quote
Hi saabcarlsson,
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
saabcarlsson
PostPosted: Tue Feb 28, 2006 12:14 am    Post subject: Thanks Reply with quote
Thanks for all your help will give it a go this weekend!!
Saabcarlsson
22.064 (26 Jun 24)
