Pocket GPS World :: View topic - Fortuna External Arial
Chorlie
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Fortuna External Arial Reply with quote
I have a CF Card Fortuna GPS receiver which works fine, but would I get a stronger and more stable signal if I bought an external arial for it. If so, is there one that will fit and where can I buy it from?
Chorlie
If it isn't broken, play with it some more...
Reception is nearly always better with an external antenna, you can locate it in the best position for optimum reception and it is removed from any electrical noise at the receiver.
Fortuna make an external antenna specifically for this receiver but I can't seem to find a stockist, perhaps an approach to the outlet where you bought it may help? Alternatively it uses an MCX connector so any external antenna that uses this connector should fit.
DavidW
As well as Darren's great advice, I replied to some issues you raised on this topic in an interesting thread that has drifted rather (it started off as about GPSAssist).
The best thing to do is link the two threads by posting a link to that thread - so here it is.
22.094 (25 Sep 24)
