spartan-ne Occasional Visitor
Posted: Mon Dec 05, 2005 3:26 am Post subject: Advice please |
Hi All
I think this is the right place to post this question.
I have a PDA running pocket 2002 (200mhz) so quite fast or was a couple of years ago. It sits in a box doing nothing, so i Thought i'd use it for sat nav. It has an SD slot on the side and a compact flash slot on top. I'm not worried about software at the moment but i cant find the power supply just yet... So I need
A PDA holding mount which will power the PDA 5v 2amp center pin+, I'm not worried about amplification just yet, I think the pda may be loud enough.
A GPS reciever for either the CF or SD slot.
I'm almost a Scotsman so it needs to be as cheap as possible and hopefully close to Newcastle to get the parts.
Help Please
Thanks |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Mon Dec 05, 2005 10:00 am Post subject: |
What exact model of PDA do you have? We need to know what memory etc it has.
I can probably tell you now that it will not run the latest versions of the sat nav packages, however it should be able to run some of the earlier ones such as the original version of TomTom, if you can get hold of it! |
alix776 Pocket GPS Moderator
Posted: Mon Dec 05, 2005 10:09 am Post subject: |
it depends o whether the is an ARM processor or not i know for fact that aa navigator will run on ppc 2002 not sure about tt5 though as ive not tested it on one of those _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Tue Dec 06, 2005 8:41 pm Post subject: |
Hello
It's a Cassiopeia E200 with 64meg on board and 128meg compact flash if needed ... Although I do have a 256meg SD in my phone i could use if needed. As far as I can tell it does use the ARM processor, and I know it deff. runs PPC2002 |
Posted: Thu Dec 08, 2005 11:34 pm Post subject: Update |
I've now found the cradle and power supply. so its fully functioning |
