Iranicus Occasional Visitor
Posted: Fri Dec 02, 2005 11:53 pm Post subject: CPU on TomTom ONE |
Hi guys,
I got a question. As you probably know, if you take off your SD card then turn on your TomTom ONE (and GO I assume) and keep the button pressed, then you'll get all kinds of statistics. The CPU speed is in there too.
Well, on my ONE it says 288Mhz If I am not mistaken it should have a 380Mhz CPU. Any idea what's happening ? Stats are wrong on that screen ? Something else ? Anyone else can check on their TomTom ONE ?
Thanks,
Iranicus |
dcwuk Occasional Visitor
Posted: Sat Dec 03, 2005 4:02 am Post subject: |
mine also says 288mhz
dcw |
soulman_lost Occasional Visitor
Posted: Sat Dec 03, 2005 4:23 am Post subject: |
Hmmm....
Not sure its says it has a 380mhz cpu
rugrat2 Regular Visitor
Joined: Aug 14, 2005 Posts: 170 Location: Hull East Yorks
Posted: Sat Dec 03, 2005 11:55 am Post subject: |
Not relevant to the one but my go 300 says 202 mghz |
MELennium Frequent Visitor
Joined: Sep 25, 2005 Posts: 337 Location: County Durham
Posted: Sat Dec 03, 2005 1:52 pm Post subject: |
Below is the specification taken from the manual, it also says 380 mhz on the box.
Specifications
TomTom ONE
l CPU: 380 MHz
l 89 mm (3.5 inch), 320 x 240 full colour TFT LCD touchscreen
l Operating temperature: - 10 C (14 F) to + 55 C (131 F)
l Dimensions: 110 mm x 89 mm x 34 mm (4.33 inch x 3.5 inch x 1.34 inch)
l Weight: 260 gram (9.2 ounces)
l 32 MB RAM
l Memory card (SD card) with software and maps
l USB port and cable to connect to a computer
l Internal rechargeable Lithium-Ion battery giving approx. 2 hours depending on use
l Alternatively power using the car charger attached to the cigarette lighter
l Integrated GPS receiver based on SiRF Star III with 20 Channel All-in-view tracking and support for active external antenna (available
as accessory). |
Posted: Sat Dec 03, 2005 8:00 pm Post subject: |
So why do we see 288 Mhz ? Defective units ? Variable speed CPU ? |
mark_r Occasional Visitor
Posted: Mon Dec 05, 2005 5:10 pm Post subject: |
mine says 288 MHz as well... |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon Dec 05, 2005 7:18 pm Post subject: |
As does my RIDER, which also claims a 380MHz processor. _________________ Tim |
Posted: Tue Dec 06, 2005 9:36 am Post subject: |
Do you think a message to TomTom support will do any good ? |
Aus Occasional Visitor
Posted: Tue Dec 06, 2005 10:23 am Post subject: |
Quite possible that the CPU voltage is lowered when the CPU is idle.
For comparison my PC's AMD 64 3700+ runs at over 2GHz but when it is idle it runs at a lower voltage and around 900MHz, therefore less heat and less cooling fan noise required! AMD CnQ (Cool n Quiet)
Athough only TT could confirm this. |
