Pocket GPS World :: View topic - Incar Power
Incar Power
Paul_D_W
PostPosted: Wed Nov 30, 2005 10:54 pm    Post subject: Incar Power Reply with quote
I've rently bought a ttg300 and am powering it using the psp charger ! Reason being that the cigarette lighter's cablind in my car has been totally removed. Does anyone have any idea's at all, if i take it to a garage, how much it would cost to have it rewired ?
sgould
PostPosted: Wed Nov 30, 2005 11:56 pm    Post subject: Reply with quote
Best way is to re-install the cig light socket (or another one behind the dash). You need one to use the charger. The charger lead cannot be cut as the plug includes a voltage regulator which drops the 12 volts of the car to 5 volts for the GO.
If you put 12 volts into the GO it starts to smoke. And then it doesn't work Crying or Very sad
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Gmonkey
PostPosted: Thu Dec 01, 2005 12:02 am    Post subject: Reply with quote
the psp charger doesnt have the same input does it??? I thought it was smmaller
PostPosted: Thu Dec 01, 2005 4:10 am    Post subject: Reply with quote
All electronic equipment comes from the manufacturer with the correct amount of smoke pre-packed inside for normal functioning. If you let that smoke out, it won't work any more.
:D
AdamSmasher
PostPosted: Thu Dec 01, 2005 7:16 pm    Post subject: Reply with quote
Yes, very be careful when using a different adapter. I've done stuff like that before and it works for a while, until that extra .5 volts melts the wires or something worse.
Paul_D_W
PostPosted: Fri Dec 02, 2005 10:53 pm    Post subject: Reply with quote
Works for me, Isn't as snug as it could be but it works once plugged in and left alone.
22.064 (26 Jun 24)
