jblackmore Regular Visitor
Joined: Nov 22, 2004 Posts: 137 Location: Somerset, UK
Posted: Mon Oct 31, 2005 6:01 pm Post subject: Anyone else lose POI-W after speed camera update ?? |
I am using Mapsonic 2.52 and realised some time ago that when updating POI's (ie speed camera's), its important to check the POI display and warn settings are not mucked up.
I just did the October updates, and found POI-D not changed, but POI-W was switched off for GATSO/TEMP but MOBCAMS was not affected ??
Anyone else noticed this, as it seems a bit bizarre, ideally updating POIs shouldn't affect the POI-D or POI-W settings at all, but for it to randomly affect them seems a bit weird, even for French software ??
Anyway, just a mention to check the POI-D/W tickboxes after updates so you don't get caught out ! |
elan2s Regular Visitor
Posted: Wed Nov 02, 2005 11:16 am Post subject: |
In the past I have had the same problem (on both v2.5 and v3.x) but this month the problem didn't occur. The only difference this month was I used the pocketgps .asc files directly into POI Manager rather than going via POI Edit |
Posted: Thu Nov 03, 2005 3:01 pm Post subject: |
I have been using the asc files for a couple of months, so maybe it is something random ??
Oh well, not a problem if you know to check after updating !! |
BaggieBoy Lifetime Member
Posted: Sun Nov 06, 2005 5:01 pm Post subject: |
I'd never had this problem before the October update, this was the first time I'd used the .asc files directly. |
