Pocket GPS World :: View topic - SPV M2000 GPS
SPV M2000 GPS
shady_cb
PostPosted: Sat Oct 22, 2005 1:53 am    Post subject: SPV M2000 GPS Reply with quote
Hey,
i Have just bought an GRB-248 GPS BLUETOOTH RECEIVER i know these arnt the best but i hope it will do me.
ALso i bought tom tom nav 5 on an MMC,
What i want to know is how easy will this be to set up and what will happen when i first put the MMC in my phone, i just to inpation Laughing Out Loud,
Also will i be able to get any updates for it over speed camara locations etc,
or any add on,
thanks
alix776
PostPosted: Sat Oct 22, 2005 2:14 am    Post subject: Reply with quote
if it will recieve a signal itll do
when you put the sd card in it wil prompt you to activate the map put in te product code you got in the pack then you will have to set the gps up use other wired gps set it 38400 then select com 5
as for the speed camera up dates yes you can do that have good read at the link below
http://www.pocketgpsworld.com/uksafetycameras.php
device Lumia 950 xl
shady_cb
PostPosted: Sat Oct 22, 2005 2:39 am    Post subject: Reply with quote
is this a setting or do i need a wierd gps rev.
Could i use this to walk around a town and find my way around if the rev was in my pocket.
Also do u reckon i will be happy with this as my first system ( daft question but even a daft answer would be good)
PostPosted: Sat Oct 22, 2005 9:44 am    Post subject: Reply with quote
The use wired GPS when in fact you are using a Bluetooth device does at first appear strange, but it does work - give it a try and you will soon find out -
best of luck but its easy to set-up, the other pointer is to put the card into a card reader and back it up on to the HDD of your PC ) don't forget to show hidden files when doing this) just incase the card goes belly-up at some point in the future,
I would also recomend a larger capacity card, then copy the files onto the new card - Mike
shady_cb
PostPosted: Sat Oct 22, 2005 10:56 am    Post subject: Reply with quote
Ok i will post here to let u know how it goes, also what siz would u suggest and why a larger on, can i get it it to locations i have been on my phone in case the mMC to small.
PostPosted: Sat Oct 22, 2005 12:20 pm    Post subject: Reply with quote
The larger card just gives you more flexibility - i.e. you can load up more than just TomTom, I use OS maps on my device for walking and TomTom for driving, having the larger card just saves swapping (read easy to loose) smaller cards around, it also allows you to put DVD movies onto the card to watch on the unit, or mp3 music files.
As for size the larger the better, the 1 Gig (1GB) cards are about the best value for money cira 35 quid.
It all depends on what you want to do with the unit if its pure sat nav for the car and a phone then the supplied card will be fine.
Cheers - Mike
shady_cb
PostPosted: Sat Oct 22, 2005 6:10 pm    Post subject: Reply with quote
kool thanks for the respond, i will let u know how i get on.
shady_cb
PostPosted: Tue Oct 25, 2005 10:52 am    Post subject: Reply with quote
hey, everything is A ok some kit, theGPs rev, is ace get full singals all all the aviable sats with is good so full signal every where,
Where will i notices the diff with my PGS rev to the more expensive ones
PostPosted: Tue Oct 25, 2005 5:34 pm    Post subject: Reply with quote
The newer more expensive units are more sensitive, and some will work in the glovèbox of the car, therefore they will also operate better in heavily buit up areas - glad to hear you got it all working - cheers Mike
shady_cb
PostPosted: Tue Oct 25, 2005 6:29 pm    Post subject: Reply with quote
Thats what i thought it would be,
Yep really happy with it all got velcrow on the dash so i can just pull of the GPs rev when i am done, if u get the one with speed camara will it warn you are have u just got to look at the screen also does the speed camara have to been on ur planned route or can u just have it tracing where iam going and it will still tell me that am approach a speed saty zone
i nkkow it a complicated question didnt know how to word it ,
PostPosted: Tue Oct 25, 2005 9:55 pm    Post subject: Reply with quote
Have a good read through the following section on this forum it should answer you questions _ mike
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=17702
shady_cb
PostPosted: Wed Oct 26, 2005 3:47 pm    Post subject: Reply with quote
hey thanks for that, i put on the speed cams and some other POIs.
what is some other good software i coulld get for my phone that might be quite usefull
PostPosted: Wed Oct 26, 2005 5:38 pm    Post subject: Reply with quote
The software you want is a personal issue depending upon what you want the PDA to do Memory Map is good for OS maps and sat nav while walking, also the spb GPRS traffic monitor is useful to watch your costs when using GPRS - Mike
22.064 (26 Jun 24)
