scrivomcdivo Occasional Visitor
Posted: Wed Oct 12, 2005 1:41 pm Post subject: How to charge iCN510 |
Am I missing something here?
Each time I plug in my iCN510, the green LED automatically comes on and it goes to power mode. Now, how do I go about getting it to charge? If I switch the power button off, it just goes to power-save mode and green LED light remains.
I want to charge my 510 at home. How do I do it? Any ideas? I don't want to use the satnav, but just charge it............ |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Wed Oct 12, 2005 6:53 pm Post subject: |
The green light shows that it is in charging mode.
So plug it in, the green light confirms, and turn off the Navigation Program. _________________ Richard
DRP Frequent Visitor
![](modules/Forums/images/avatars/135424442845559c56e06a2.jpg)
Joined: Mar 03, 2004 Posts: 353 Location: "The Green Green Grass of Home"
Posted: Wed Oct 12, 2005 7:47 pm Post subject: |
Just read your post. Turned on 510 & battery warring came up on screen. I plugged it into the mains in standby mode.
Amber power light came on, it will change to Green when fully charged. (It has always done this). I am not an electrician, but my belief is that, it dose the battery good if you let it fully discharge from time to time & not top it up all the time as you get a turm ‘battery memory’ this is common with rechargeable’s and when they reach the minimum top up memory the battery will start to shut down. Giving you perhaps 1 hr duration in stead of several hrs.
Regards
DRP _________________ Sharing information is the key to a better understanding
Mio M400 WEU, N60I, T1, 2x B2, iCN 510 & lots more |
Posted: Wed Oct 12, 2005 8:05 pm Post subject: |
If, as I believe, there is a lithium-ion battery in the 510 then doing a complete discharge is not a good thing. It's chemical nature is totally different to a rechargeable ni-cad battery, and your advise would apply to that type. _________________ Richard
Posted: Wed Oct 12, 2005 8:23 pm Post subject: |
Hi Oldboy
As I said I am not an electrician so if I am wrong I apologise for any miss directions. I have just read the manual and it quotes that in charging mode it is amber & goes to green when fully charged.
Sorry for any misleading comments as it was not intentional.
Regards
Posted: Wed Oct 12, 2005 8:41 pm Post subject: |
Hi all
I Stand Corrected & Oldboy is correct, so if I could edit my post I would.
Here is a paragraph taken from “BATTERY UNIVERSATY.COM”
How to prolong lithium-based batteries
A lithium-ion battery provides 300-500 discharge/charge cycles. The battery prefers a partial rather than a full discharge. Frequent full discharges should be avoided when possible. Instead, charge the battery more often or use a larger battery. There is no concern of memory when applying unscheduled charges.I will now change my charging habits with my ICN 510
Regards
Posted: Wed Oct 12, 2005 9:44 pm Post subject: |
Oldboy wrote: | The green light shows that it is in charging mode.
So plug it in, the green light confirms, and turn off the Navigation Program. |
How do I turn off the navigation programme? Just by leaving it on the menu page and then pushing the on/off button? |
Posted: Wed Oct 12, 2005 10:07 pm Post subject: |
Check Page 9 of the manual, should do the trick, and explain with graphics. ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Richard
Posted: Thu Oct 13, 2005 4:11 pm Post subject: |
STILL HAVING PROBLEMS....................
When I plug my iCN510 into the charger and go to the Harware>Power Status screen, it says that 'External Power Status' is 'ON' and 'Internal Backup Battery Charge' as 'CHARGING' however it doesn't show any percentage. This subsequently contradicts what the instruction manual says. Likewise, the LED is still coloured green and not amber.
Any ideas? I know that the battery isn't charged as it is will not switch on at all without an external power source
[/img] |
Posted: Thu Oct 13, 2005 7:38 pm Post subject: |
Hi.
Go to More Settings, Hardware, Power options, uncheck both settings, escape & save settings. You may have it set on internal 10 seconds, which will give you the impression that it is not working.
Regards
Posted: Sat Oct 15, 2005 3:45 pm Post subject: |
Should the battery tab on the back of the Navman be switched to ON or OFF when charging? |
Posted: Sat Oct 15, 2005 5:42 pm Post subject: |
OK...............I still can't get it to charge!!!!!!!!!!!!!!1 :x
The battery switch on the read of my Navman iCN510 is switched to on. I plug it into the mains and it loads maps etc.... Then it goes to the menu page. When it's on this page, I push the power button so that the screen goes off. The green LED remained illuminated. Now, I left my unit to charge on mains for 24 hours, however when I unplugged the unit from the mains it still didn't switch on without an external power source.
Where am I going wrong? |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Mon Oct 17, 2005 5:50 pm Post subject: |
scrivomcdivo wrote: | OK...............I still can't get it to charge!!!!!!!!!!!!!!1 :x
The battery switch on the rear of my Navman iCN510 is switched to on. I plug it into the mains and it loads maps etc.... Then it goes to the menu page. When it's on this page, I push the power button so that the screen goes off. The green LED remained illuminated. Now, I left my unit to charge on mains for 24 hours, however when I unplugged the unit from the mains it still didn't switch on without an external power source.
1. If your led indicator is Green when connected to either a mains or car battery charger, it means the battery is fully charged. If it is amber, it is charging. Red is low.
2. If you go to Settings > More Settings > Hardware > Power Status, it will show you the state of your battery ie (External power status "Off" Internal Backup battery Charge, Green 66% and higher or Amber 33% & lower).
If you have charged for 24 hours and the led indicator is green then the battery should be fully charged and you should be able to use your iCN510. When you switch on, if there is no external power source, there should be no led indicator.
Press the ON button once only and wait. NO effect? Then check that the battery switch on the back is in the ON position. Now try switching on again and then press (with the stylus) the RESET button. (Alternatively, press and hold down the Home button (the one with the little house) to reset)
If you have no luck after all that, I suggest you may have a fault - contact Navman support.
When I first got my Navman, I was impatient for it to switch on or respond and inadvertently caused it to freeze by pressing buttons to fast. Always press them ONCE and wait.
Good luck ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Mon Oct 17, 2005 8:23 pm Post subject: |
Many thanks all for the advice, especially Gee-pee.
Well it's still not working so I don't know what is wrong with it. I will post my problem to Navman's technical support, but their website is down at the moment so will have to try later. |
Posted: Tue Oct 18, 2005 7:35 pm Post subject: |
OK, here's what the technical "support" have to say..........
"We do not offer any technical support for our products that are purchased via eBay, please refer to www.navman-store.com where you will find details of our policy with regards to eBay."
Oh well................back to square one! |
