Pocket GPS World :: View topic - HP ipaq and Globalsat br-305 ps2 help
rps_1969
PostPosted: Thu Oct 06, 2005 2:38 pm    Post subject: HP ipaq and Globalsat br-305 ps2 help Reply with quote
First & foremost I would like to say hi to everyone as I’m a new member here. Which is going to lead me to a question some of you may have the answer to, so here goes.
HP Ipaq 2210 – TomTom Navigator 5 with 5.1 update – Globalsat br-305
The problem is this?
I have installed TomTom 5 with the update 5.1 and all seems o.k on the pda. When it comes to loading the software off the Globsat cd it first downloads onto the pc and then automatically onto the pda via sync. Reading the info on the disc it says I should be able to check that the gps is working by going into gps info on the pda and clicking I think it’s the search button, which I do. Problem is when I press the search button it does nothing, but the grp does have the red light on, but not flashing. It is also not possible to check com ports as it always reverts to com1.
Thinking maybe I do not have to do this I then go into TomTom to select gps receiver that is hooked up. Hell I have no idea what the correct port should be but have tried them all, but the dreaded “no gps device” is all it says.
Is there anyone out there who can shed some light on this for me as to where I may be setting it up wrongly, and if you do know please explain it like I’m a 10yr old.
Many thanks
Rich
PostPosted: Thu Oct 06, 2005 6:50 pm    Post subject: Reply with quote
How have you configured the GPS, try "Other wired NMEA GPS", then select the correct Baud speed (check the documentation it came with or look for the manual on the CD for it), at the next screen select Serial Cable on COM1. Then with it all plugged up and running sit with it for around ten min with a clean line of sight to the sky - it could take as long as this to acheive lock on for the first time. - Mike
rps_1969
PostPosted: Thu Oct 06, 2005 9:23 pm    Post subject: Reply with quote
Hi mikealder
Many thanks for letting me know this info. And taking with me all what you advised guess what, Found gps in about 7 sec's, so many thanks.
I cannot for the life of me understand why it did not do this the other day, but who cares ah !!!!
Yet to test it out with TomTom 5 as am leaving it on the roof for about 30 minutes just incase. Hoping i do not get into anymore difficulties but i now where to come if i do ?
Again, Thanks
Rich
PostPosted: Thu Oct 06, 2005 9:25 pm    Post subject: Reply with quote
Don't leave it outside - it might rain, if its found the sats then it will be OK for the rest of the time, glad you got it working - and enjoy using it - Mike
22.064 (26 Jun 24)
