Pocket GPS World :: View topic - which files?
which files?
Nobby10
PostPosted: Mon Oct 03, 2005 8:21 pm    Post subject: which files? Reply with quote
HELP!
I've downloaded the camera database to put on my i3, but don't know what files I need to install (ie what csv filef from what folder)
Can anyone help?
Minidish
PostPosted: Mon Oct 03, 2005 8:39 pm    Post subject: Reply with quote
After extracting files open the folder called csv files then inside that folder open folder called other, they are the text files you want but before you upload them to i3 you need to get the bmp files (little camera pictures that will show on i3) they need to be in same folder as the csv files-other folder as above. they can be found in the ov2 bmp files folder. just copy and paste them into folder as above, you only need the bmp files not the ov2 files but it won't do any harm if you paste all the contents of ov2 bmp files folder into folder mentioned above.
Just a quick reply if you need more info just ask
Nobby10
PostPosted: Mon Oct 03, 2005 8:58 pm    Post subject: Reply with quote
Superstar!
Thanks for that!
Will I need to copy any of the .wav files to get the audible warning?
Minidish
PostPosted: Mon Oct 03, 2005 9:07 pm    Post subject: Reply with quote
I may be wrong but as far as I understand it the wav files can't be imported into the i3 more for tom tom I think. you should get a bonging sound as you near the cams the distance is dependant on the settings you select when uploading to i3.
Nobby10
PostPosted: Mon Oct 03, 2005 9:15 pm    Post subject: Reply with quote
thanks mate
23.032 (12 Mar 25)
