Pocket GPS World :: View topic - help loading speed camera on pda!!!
tont
PostPosted: Mon Oct 03, 2005 1:34 pm    Post subject: help loading speed camera on pda!!! Reply with quote
Please can somebody talk me through how to load speed camera on my pda dell x5, i have managed to load the tomtom navigator 3 on but i cant figure out how to load the speed camera's on it. when i bought the pda it was working, but it went flat and lost all the info, so now i have to reload everything, cant understand why it goes flat witin a week of not being used though, anybody else had the same problem? thanks a lot.
tanda
PostPosted: Sun Oct 23, 2005 5:22 pm    Post subject: Reply with quote
Hi Tont, When you switch your PDA off, power is used to store programs etc in RAM, if the battery goes flat, You loose everything in Ram, which is what has happened to you. When you switch your PDA off, make sure all running programs are closed, or they will continue to run in the background, even when the PDA is off. Finally, It may be wise to invest in "sprite Backup" you can backup your PDA, in an " exe" file, and store it on an SD card or similar, so if you loose everything from your PDA, clicking on the "exe" file will restore everything. I have a 60 day trial vertion at the moment, check it out here.
http://www.spritesoftware.com/en/personal/products/index.htm
Audi A3 Sline sat nav
PostPosted: Sun Oct 23, 2005 5:50 pm    Post subject: Reply with quote
For the actual warnings to work you will need checkPOI from this site (downloads) from home page, rh side. Get the correct version applicable to the tt vs you are using - cheers, mike
PostPosted: Sun Oct 23, 2005 5:52 pm    Post subject: Reply with quote
PostPosted: Sun Oct 23, 2005 5:54 pm    Post subject: Reply with quote
Sorry got the shoes on the wrong feet, I meant LH side of the home page, try this link
http://www.pocketgpsworld.com/modules.php?name=Downloads&d_op=viewdownload&cid=3
you whant vs 3,2 - mike
tont
PostPosted: Sun Nov 27, 2005 1:03 pm    Post subject: thanks Reply with quote
thanks everyone managed to sort it now.
22.094 (25 Sep 24)
