Pocket GPS World :: View topic - Trouble activating tt5 on transcend cf Card
steve_62
PostPosted: Sun Oct 02, 2005 10:05 pm    Post subject: Trouble activating tt5 on transcend cf Card Reply with quote
Hi Guy's , I was told this is the best place to find the solution to my problem , so here goe's.
After reading the topic's in this forum to solve the problem on my xda of tt5n loosing / freezing up when recieving a phonecall , i bought a transcend 80x cf card , ( the topic was on sd card) hoping the faster speed of the card etc would solve the freeze-up . The problem i have now is that tt map's are copied ok to the card , but when i start tt the tt program freeze's , only a soft reset will unfreeze, I have tried 2 other make's of cf card and they both start-up and work fine but i am desperate to try my transcend to try and solve the first prob . Could anyone tell me why my all singing all dancing transcend card wont play ball ??? Could the card be faulty? or i've not loaded prog properley? Look forward to any reply's steve
PostPosted: Sun Oct 02, 2005 10:42 pm    Post subject: Reply with quote
Welcome to the forum - exactly which XDA do you have as there are a number out there (use the sig in profile to let others have an idea as to the hardware etc) - are you using a CF or SD card if so which ne and which phone? - Mike
steve_62
PostPosted: Mon Oct 03, 2005 6:44 am    Post subject: Reply with quote
Here's my detail's , steve
XDA 2
ROM 1.72
ROMDATE 03/15/04
RADIO VERSION 1.17.00
PROTACOL VER 1337.28
EXT ROM VER 1.72.28
TRANSCEND CF CARD 512mb
SD Card gps rec
PostPosted: Mon Oct 03, 2005 8:39 am    Post subject: Reply with quote
As a starter I would try re-formatting the SD card, then copy the data back on to it - Mike
steve_62
PostPosted: Mon Oct 03, 2005 6:05 pm    Post subject: Reply with quote
Hi, Mikealder,
I've tried formatting the card but the same result at the end , is there a way to format through the xda or can it only be done on the pc?. I'm starting to think i've got a duff card . steve
XDA 2
ROM 1.72
ROMDATE 03/15/04
EXT ROM VER 1.72.28
SD Card gps rec
PostPosted: Mon Oct 03, 2005 8:22 pm    Post subject: Reply with quote
Is it an O2 unit if so have a look at there web site and check the OS ROM version you are using against the latest one, another trick to try is check if you are running the device in corporate mode or personal mode if its the later then you will have the O2 active interface on the desktop on the PDA, get rid of it by performing a hard reset and sit with the PDA when it loads the applications, at the end you can select Corporate mode (you only get around ten seconds or so - keep your eyes on it) then when prompted enter the code 0506 and the active interface won't be installed. - Mike
steve_62
PostPosted: Mon Oct 03, 2005 8:53 pm    Post subject: Reply with quote
Hi, Mike,
Thank's for the help, i've got the latest rom upgrade that's on the o2 site, If i do a hard reset and put it it corp mode will i be able to restore from the back-up copy or will it restore ALL setting's , as i have a lot of stuff in contact's etc ??? steve
XDA 2
ROM 1.72
ROMDATE 03/15/04
EXT ROM VER 1.72.28
SD Card gps rec
PostPosted: Mon Oct 03, 2005 9:00 pm    Post subject: Reply with quote
OK back up the contacts as a seperate file as that is the ONLY thing you will be able to restore afterwards, DO NOT put any software back on to the PDA from backup as it will put the O2 rubish back on - the sooner O2 realise this and stop selling/ supplying these devices with rubish pre-loaded the better (hint hint) - its even the first thing their customer support sugest - so they know about the problem, it turn a quality device into a useless device IIi and IIs - Mike
steve_62
PostPosted: Tue Oct 04, 2005 7:09 am    Post subject: Reply with quote
Mike ,
Done the hard reset last night ,everything ok, then reloaded map's on to the cf card and the bloody thing froze up again after activation , it's got to be the cf card that is the problem ? dont you think?,
Thank's again for you're help will have to wait for a reply from the shop were i bought it from . Steve
XDA 2
ROM 1.72
ROMDATE 03/15/04
EXT ROM VER 1.72.28
SD Card gps rec
22.071 (03 Jul 24)
