Pocket GPS World :: View topic - PiN 570 POI Editor
PiN 570 POI Editor
keitht
PostPosted: Tue Sep 20, 2005 3:22 pm    Post subject: PiN 570 POI Editor Reply with quote
I have a Navman PiN 570 with the camera database pre-loaded by the supplier. The camera Icons are on the map and it works perfectly.
When I go into the POI Editor it says “No customer POI files loaded”.
If I download the new database and install it, it puts a second set under ‘Active’ POI’s and this set appears in the POI Editor. Deleting it does not affect the operation of the original set. I am now wondering where the original files are stored and how I update the camera database.
Can you help?
Keitht
Tim Buxton
PostPosted: Tue Sep 20, 2005 6:16 pm    Post subject: Reply with quote
I'm trying to get a loan of my neighbour's 570 to have a look. Can you explore both main memory and SD card for a directory called MyPOI and tell me what is in them?
Tim
keitht
PostPosted: Wed Sep 21, 2005 12:00 am    Post subject: PiN 570 POI Editor Reply with quote
Dear Tim,
Thankyou for your quick response.
The files on the SD card in My POI are as follows.
Continen, Gatso, Mobile, Redlight, Specs, Temp, each with the following extensions
.bm .chk .ini .map
The files I downloaded in the camera database have the extensions .csv and .bmp
There are no files on the device in My POI.
Tim Buxton
PostPosted: Wed Sep 21, 2005 7:02 am    Post subject: Reply with quote
You need to transfer the new files using POIEditor, not by direct copy. Make sure you use the correct .csv files and edit them using [color=red]Notepad[/color} before trying to transfer them.
Tim
