Pocket GPS World :: View topic - Help please.
Help please.
cabmanuk
PostPosted: Tue Sep 20, 2005 10:25 am    Post subject: Help please. Reply with quote
Hi everyone great site,i am a completley new to all this Laughing Out Loud, i just got a tom tom go 300 and the memory card i got with it is 128 mb i would like to change it can i buy any memory card or does it need to be a certian one,also do i back all the info on the first card onto the new one Laughing Out Loud sorry as i said i am new to this. :D
carmex
PostPosted: Tue Sep 20, 2005 11:00 am    Post subject: Reply with quote
If you want to change your memory card you need to look for an SD card as that is what your TomTom Go uses.
Once you have your new card then you need to make a back-up of your existing card on to your pc (either using a card reader/writer or by connecting your Go to your pc with a USB cable) and then copy and paste the back-up onto your new card - it's that simple.
Are you wanting a larger card for more map data?
Owen
Product Manager
www.globalpositioningsystems.co.uk
YooNoo LTD
owen.haigh@yoonoo.co.uk
www.globalpositioningsystems.co.uk - GPS System Specialists
sparkey
PostPosted: Tue Sep 20, 2005 12:09 pm    Post subject: Reply with quote
Nice to see you on the boards cabmanuk have a look at link for compatible sd cards.
http://www.mytomtomgo.com/special_faq.php#77
cabmanuk
PostPosted: Tue Sep 20, 2005 2:21 pm    Post subject: Reply with quote
Thanks Carmex and Sparky for your replies,yes i am looking to get a larger memory card so i can add more info,i added the speed cameras on ok but then i tried to add the voices on but it says no enough space on the memory card, my card is 128mb the one you get with the tomtom. Laughing
Kavg
PostPosted: Tue Sep 20, 2005 6:23 pm    Post subject: Reply with quote
Hi Cabmanuk,
You need a bigger SD card. 128mb is not big enough for what you are trying to do, you need at least 512mb, or even better a 1GB (just in case you add lots of stuff e.g maps later).
Firstly you need to backup all the files from your 128mb card on to your PC hard disk, then you then need to copy all the contents of you original card to the new card, and pop the new card into your TT. (keep the original card safely away)
Try one from ebuyer. I currently use the Viking 512mb SD card on my TT500 and its been working fine.
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=43743
--Kav.
cabmanuk
PostPosted: Wed Sep 21, 2005 2:18 am    Post subject: Reply with quote
Thanks Kavg will look on that site,thanks for your help,All the best. Laughing
PostPosted: Wed Sep 21, 2005 1:47 pm    Post subject: Reply with quote
From Jay-cee on the 'other' forum:-
May be worth pointing out that Tom Tom requires Sd cards with a minium of 10Mb/s read/write ( x66) most cheap cards are slower than this!
posa2000
PostPosted: Tue Nov 22, 2005 10:41 pm    Post subject: S D Card Reply with quote
I've recently purchased a TT300 and decided to buy an additional SD Card to use in the TT300 and keep the original safe.
I'm copying the files from my original backup via my TT300 after having first formatted the new card. When I now start up the TT300 with this new card in I get a picture of a card with a red cross through it - have I done anything wrong here?
For information purposes the new S D Card is a Kingston Elite Pro 512mb.
Any advice would be appreciated.
sgould
PostPosted: Tue Nov 22, 2005 11:21 pm    Post subject: Reply with quote
Compare the size of files on the two cards. You may have disconnected the GO too soon and not transferred it all. It needs to be "safely removed" via right click.
The screen of the GO flashes when transfer activity occurs. You need to wait a bit after it stops just to make sure.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
posa2000
PostPosted: Wed Nov 23, 2005 12:38 am    Post subject: S D Card Reply with quote
I think that's worked thanks.
Proof of the pudding will be when I use it tomorrow.
Cheers.
22.063 (19 Jun 24)
