The_Stig Occasional Visitor
Posted: Mon Sep 19, 2005 11:56 pm Post subject: Newboy on the Block. |
Hello all,
Just got Tom Tom Nav 5 blootooth .. after a bit of fun pairing up the GPS receiver with my PDA ipaq 4150 I was off ... Navigated myself to my old address and back again ( nearly crashed twice because I was totally amased at watching the 3d map showing where I was ) :P ..
Then I upgraded to 5.1 and that went smoothly ..But next I thought I would add the speed camera POI's .. Now here comes the silly question.. I installed tom tom with the SD card provided.. And when I read the destructions for adding the osv and bmp files , it ses to put them in the map directory .. Now I guess that the SD Card with the software and maps is read only so I won't be able to do that .. correct ? so do I have to get another SD card and copy the software onto that then add the POI's ..
Sorry if its a silly question but I am fairly new to this stuff ..
THANKS IN ADVANCE
Regards
Steve |
rayflan Frequent Visitor
![](modules/Forums/images/avatars/265178757431f9c5ddb971.gif)
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Sep 20, 2005 12:16 am Post subject: |
The SD card will be read only if the small tab on the side of the card is set to that position, the files you need are in the folder named
ov2 bmp files
open the folder, then copy the 12 files, then paste them to the map folder on your sd card via ActiveSync, then you need to configure TT5 via the menu's, that's it, go navigate, but note the files for the Safety Camera's may never be 100%, so be careful. |
Posted: Tue Sep 20, 2005 12:44 am Post subject: |
Thanks guys that did the trick.. :D never used sd cards before .. slid the little tab over and hey presto I could write to the card..
Made sure I backed it up first though ..
Thanks Again
Best Regards
Steve |
