Pocket GPS World :: View topic - Home location and other settings not being saved
benf
PostPosted: Thu Aug 18, 2005 11:12 am    Post subject: Home location and other settings not being saved Reply with quote
Using Tom Tom 5 on a Nokia 6680 and having a few annoying little problems.
For some unknown reason, despite setting my home to where I actually live, each time I start up the application it defaults back to another location. Anyone know why this is?
Also, some times when I start TT5 the sound is turned off, even though I haven't turned it off when using the application
Finally, TT5 seems unable to save my BT device as the dreffered GPS device. Each time I start the app I have to go to preferences, GPS Device and configure it.
Anyone know why this it?
PostPosted: Thu Aug 18, 2005 7:24 pm    Post subject: Reply with quote
The .cfg file in your Map Folder is probably Read-Only. You will need to change it attributes by un-ticking the Read-Only box.
You might have to copy the file to the PC to change it, and then copy the file back. Remove the old file before copying back.
benf
PostPosted: Fri Aug 19, 2005 11:08 am    Post subject: Reply with quote
Hi Oldboy, I'm afraid the .cfg files aren't 'read-only'. Just copied them to my PC to check Sad
Any other ideas what it may be?
PostPosted: Fri Aug 19, 2005 7:16 pm    Post subject: Reply with quote
It's not something silly like the write protect switch on the card is it? Especially if it's loose.
benf
PostPosted: Mon Aug 22, 2005 10:49 am    Post subject: Reply with quote
Hi Richard, sorry, I am not sure what you mean by that?
Do you mean a physical switch on the MMC?
PostPosted: Mon Aug 22, 2005 12:20 pm    Post subject: Reply with quote
Yes. Some cards have a small slide switch on them.
benf
PostPosted: Mon Aug 22, 2005 12:24 pm    Post subject: Reply with quote
I see, no, mine does not so I suppose it isn't that. Sad
PostPosted: Mon Aug 22, 2005 12:37 pm    Post subject: Reply with quote
That leaves me lost for ideas. Have to do a search around to see if I can find anything.
steve67474
PostPosted: Mon Aug 22, 2005 2:24 pm    Post subject: Reply with quote
I had this problem and what I did was copy the Great britain map off CD to your desktop and take off the read only flag on the folder then copy the map from your desktop to your SD card. It fixed it for me
benf
PostPosted: Wed Aug 24, 2005 12:00 pm    Post subject: Reply with quote
I have checked the files and all the folders have read and write access. Bit stuck for what else to try??
alladin
PostPosted: Fri Aug 26, 2005 5:22 pm    Post subject: Same problem Reply with quote
I have the same problem and have tried all the suggestions to no avail.
Is there any way to edit out the rogue home location???
alladin
PostPosted: Fri Aug 26, 2005 5:32 pm    Post subject: Sorted Reply with quote
Changed the attributes of Great britain Map within the Great britain map folder, now changes
