bocher Occasional Visitor
Posted: Mon Aug 15, 2005 2:18 pm Post subject: MEDION MD95900 / NAVIGON multiple countries on one MMC issue |
I have a Medion 95900 (Navigon compatible) and all works fine - except..
I am trying to get more than one country on the MMC card but the system will only find one country at a time
- the card has more than enough space
- have tried soft and hard resets
Only solution I can find right now is to have a separate MMC card for each country so that when I go over a border I have swap cards, do a soft reset and I can proceed.
However this is obviously not optimal as I cannot navigate cross border and the incovenience and expense of the extra cards
Any ideas anyone?
thanks |
twinfanman Regular Visitor
Joined: Jul 13, 2005 Posts: 100 Location: Bracknell, Berkshire
Posted: Sat Oct 01, 2005 2:32 am Post subject: Re: MEDION MD95900 / NAVIGON multiple countries on one MMC i |
bocher wrote: | I have a Medion 95900 (Navigon compatible) and all works fine - except..
Any ideas anyone?
thanks |
Did you ever conclude this? It seems like it should have been thought about by Medion, so if you got a fix I (and others) would like to hear about it! |
Roy124 Regular Visitor
Posted: Tue Oct 04, 2005 8:00 pm Post subject: |
On my Navigon FAQ they explicitly rule out cross border navigation. The best you can do is to navigate to the edge of the map and then change maps. In my PDA I could change maps within the software.
Now I am guessing but there are two possibilities.
With the original TCM software I had there was a possibility to create a route and set it to cover a given width, say 50 miles either side of track, and then save this smaller map file to the PDA MMC. This would cope with a European size map that was both too big for the MMC or would take too long to load and search.
The other possibility may be to get a 'high level' pan European map that will give you the fast motorway transits and then switch to a large scale map for the gravy strokes. Again I don't know if that exists. |
smartwombat Occasional Visitor
Posted: Wed Oct 05, 2005 1:56 am Post subject: |
I've run into exactly the same problem, different symptoms.
I can load 6 map folders on to a 1G card.
The software only shows me the first 3 in alphabetic order.
If I choose any one in the Select Map option, it tells me I have to restart.
So I restart the app, select a map.
Tells me I have to restart.
Lather, rinse, repeat
So I am reduced to using one SD memory card for each country.
PAul |
