ianhb Occasional Visitor
Posted: Fri Jul 15, 2005 7:05 pm Post subject: TTN5 in full screen mode on a T3 |
I used to have TTN4Palm and upgraded to TTN5. I'm pretty sure that I could run v4 in full screen mode on my T3 but I don't to be able to run v5 in full screen.
Am I being particularly dumb, or forgetful, ror what?
Can anyone else run v5 in full screen on their T3?
Thanks,
Ian |
dickdastarley Occasional Visitor
Joined: Jun 12, 2005 Posts: 14 Location: Merseyside, England
Posted: Fri Jul 15, 2005 9:21 pm Post subject: |
I am using v5 with full screen mode on a T3 with no problems. |
Posted: Fri Jul 15, 2005 10:41 pm Post subject: |
How do you get full screen mode. On my T3 the palm icon in the bottom right corner is greyed out :/
Ian |
Posted: Sat Jul 16, 2005 1:01 am Post subject: |
mine automatically runs in full screen, the only time mine is grayed out is when i'm using the small screen.
have you installed the Palm T3 full screen update, although if full screen mode was working when you were using v4 it should automatically work on v5.
can you use the keyboard (input key) on any other program other than TT5, if not i don't think this is a problem caused by TT5, if you can then it must be TT5 and i don't know what caused it to stop working. |
Posted: Thu Jul 21, 2005 2:11 pm Post subject: |
dickdastarley wrote: | have you installed the Palm T3 full screen update, although if full screen mode was working when you were using v4 it should automatically work on v5. |
What is this 'full screen update'? the only update that I can find is for SD cards on the palmone website. My current T3 is a different device to the one I was using with TTNv4 so your conclusion may not be valid...
dickdastarley wrote: | can you use the keyboard (input key) on any other program other than TT5, if not i don't think this is a problem caused by TT5, if you can then it must be TT5 and i don't know what caused it to stop working. | Apps like NotePad and Calendar work in full screen and can be swiched to part screen with input area by clicking the bottom-right-corner icon :/ |
Posted: Thu Jul 21, 2005 9:32 pm Post subject: |
My mistake tomtom t3 full screen update.
its been years since I've had to install this.
go to tomtom website /support / navigator for palm in the drop down box.
the update is half way down the list. |
Posted: Tue Aug 09, 2005 10:44 am Post subject: |
Found it. Installed it. Sorted! :D
Thanks,
Ian |
