Pocket GPS World :: View topic - XDA IIs / Tom Tom5
XDA IIs / Tom Tom5
emul
PostPosted: Fri Jul 29, 2005 9:26 pm    Post subject: XDA IIs / Tom Tom5 Reply with quote
I have ordered with asking anyone here 1st the following, so if I've got it wrong - be gentle !! :
TomTom5 Navigator
Blue tooth GPS Receiver - NMEA compliant
1Gb SD Card
Couple of questions
1. Any suggestions on tweaks etc to XDA to get best results?
2. As above but for TomTom
3. I am based in Southern Ireland, Cork - anyone know if Tom Tom includes any part of Cork / Ireland so I can test this all out
EMUL
PostPosted: Sat Jul 30, 2005 9:10 am    Post subject: Reply with quote
Only Northern Ireland is on the map, as for the XDAIIs - I have problems with BT GPS unit when using a BT headset, when you finish a call it terminates the GPS, real pain in the neck when on the motorway at speed
so in the end to fix the prblem I use a wired GPS and BT headset - no problems there. If your phone service provider puts an active front end on to the PDA (like O2 do in the UK) don't load it it makes the device unstable - finally one this all XDAIIs suffer from is the no sound when using it as a phone - can be annoying - at first I used to soft reset the deviceto cure the problem but then found out if you turn the bluetooth on then off the sound will return - bizzare - hope this gives you some idea of what to expect - Mike
22.064 (26 Jun 24)
