korndog Lifetime Member
Posted: Sat Oct 15, 2005 8:23 pm Post subject: XDA IIi set up |
Trying to set up an XDA IIi for a colleague and having great difficulty getting it to see my Leadtek 9537. It works on my XDA II. What am I doing wrong? |
alix776 Pocket GPS Moderator
Posted: Sat Oct 15, 2005 8:46 pm Post subject: |
if its wired gps then it might not work as a production process changed on 2i and it messed up the serial port for gps if its a bt gps the use bt on com 6 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Oct 15, 2005 9:16 pm Post subject: |
Cheers for the prompt reply but I thought you'd know that the 9537 is a bluetooth.
I can get a wired gps to work with the IIi but not bluetooth. My XDA II is set up on com 5, so I did the same on the IIi. I think I tried com 6 and I tried pairing in bluetooth manager but still nothing |
Posted: Sat Oct 15, 2005 9:53 pm Post subject: |
im usless with names and number s unless it a truck and product numbers go in one ear and out the other usually _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
hyjacks Occasional Visitor
Posted: Sun Oct 16, 2005 2:43 am Post subject: |
in gps settings (config) set the gps reciever to a wired device on com 6 should work. |
Posted: Sun Oct 16, 2005 2:44 am Post subject: |
dont use bluetooth setting it dont work it has to be other wired device : ) |
Posted: Sun Oct 16, 2005 5:00 pm Post subject: |
cheers, it works now. Well done that man :D :D |
Posted: Sun Oct 16, 2005 9:55 pm Post subject: |
hyjacks wrote: | dont use bluetooth setting it dont work it has to be other wired device : ) |
is it the same for the tomtom bluetooth receiver? |
Posted: Sun Oct 16, 2005 10:09 pm Post subject: |
yes i use my mk1 tt gps on other wired personally _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Tue Oct 18, 2005 7:41 pm Post subject: |
Thanks, I will pass that info on :D |
