Haz Occasional Visitor
Posted: Mon Jul 25, 2005 9:42 pm Post subject: medion ppc150 use tom tom 5 |
i am having difficulty using tomtom 5 navigaytor on my MDPPC150.
i have installed the software however it says "NO VALID GPS SIGNAL FOUND"
im using settings gps connect : NMEA-0183 |
Posted: Mon Jul 25, 2005 9:46 pm Post subject: Re: medion ppc150 use tom tom 5 |
Haz wrote: | i am having difficulty using tomtom 5 navigaytor on my MDPPC150.
with GPS baud 4800
serial cable on COM 1 ( i have an internal antenna on this pocket pc)
anyone help
cheers
skr80 Occasional Visitor
Posted: Sat Jul 30, 2005 6:34 pm Post subject: |
I am also having the same problem - did you sort it? |
shaun_uk Occasional Visitor
Posted: Sun Jul 31, 2005 1:20 pm Post subject: |
any of you have any luck? |
Posted: Sun Jul 31, 2005 3:08 pm Post subject: |
mine works ok with the same settings, only thing i cant get working is the signal strength meter.it picks up the sat's but i have no idea how many. |
Baffled Occasional Visitor
Posted: Wed Jul 18, 2007 10:21 am Post subject: |
please help... tried to update the firmware and was unsuccessful and now can't get a signal? |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed Jul 18, 2007 2:25 pm Post subject: |
Try the Mio 168 settings. Other - NMEA, Baud - 4800, On SP2.
If not try TomTom GPS. |
Posted: Fri Jul 20, 2007 1:03 am Post subject: |
Lost_Property wrote: | Try the Mio 168 settings. Other - NMEA, Baud - 4800, On SP2.
Thanks tried all that and something seems to happen with the SP2 but left to run for over 30 mins but nothing....???????????? |
Posted: Fri Jul 20, 2007 9:26 am Post subject: |
Quote: | Thanks tried all that and something seems to happen with the SP2 but left to run for over 30 mins but nothing....???????????? | Some time back some people said they had to wait for up tp 45 minutes for the first fix after installation. The same thing would apply if you hadn't used the device for several days or you moved a long way away from your last position with the unit off.
On the Mio 168 there was a small blue/yellow spinning ircle to indicate it was searching for a signal.
Are you going outside under an unobstructed sky? Indoors on in a car, especially with an athermic windscreen, you may not get a lock. |
