cityboy Occasional Visitor
Posted: Thu Jul 21, 2005 10:02 pm Post subject: Medion MD 95900 problems |
Anybody point me in the right direction please!!!!
I have the MD95900, bought from ALDI but note that the maps supplied are UK/Ireland with main European roads only(?) I am off to France in August and wanted more detailed maps. Question. Are these the only maps supplied or am I missing someting obvious like others available on the CD's supplied? Because if they are I can't see 'em.
Also problems using SD card for mp3 player - I think it has been mentioned before but once I take out the supplied MMC and insert a SD card (formatted FAT32) it is not recognised as being there, either on my PC exploring 'mobile device' in Activsinc' or by the unit itself when trying to access the MP3 player.
Any help please would be appreciated.
Thanks in anticipation!! |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Jul 22, 2005 1:23 am Post subject: |
How many CD's do you have, a full set with the euro coverage consists of 4 cd's, if you have them then you would have a program on disc 1 called map export, that you load to your main pc then when run you can export the different euro maps to your unit via activesync or to the card via a card reader.
As regards your SD card, some card readers will not load the files to the card in a format that the pna or pda like, you will need to place the files from your card onto your main pc, then place the card into your pna and then transfer them via ActiveSync, which I know takes for ever, but just try one or two tracks to see if that works ok.
I was going to have a look on the Medion shop for any euro maps, but the web site is closed for update at the time I posted this, but this is the url
https://www.medionshop.co.uk/ |
Posted: Fri Jul 22, 2005 8:31 am Post subject: |
Thanks for the speedy reply.
I only have 1 cd with maps on it - Any idea where I could obtain French maps for the unit?
I will try out another SD card later today to see if it makes a difference and also try to get files over via ActivSync. I also only seem to be able to connect as a guest and not form a full 'partnership' with my PC - should I still be able to transfer files via ActivSync with this connection?
Many thanks again. |
snip Occasional Visitor
Posted: Fri Jul 29, 2005 9:48 pm Post subject: Try the pocket earlier pocket PC maps |
I lent a friend my new 95900. He was going to France and Italy.
I put the supplied maps + maps for France and Italy that I had from a Medion Pocket PC navigator (the previous one from ALDI) on a 1GB card from ALDI.
It showed up a 3 different maps on the select map menu. You just had to select the one you wanted, then it asked you to do a soft reset and away it went.
Hope this helps
Snip |
Stumartin Occasional Visitor
Posted: Fri Jul 29, 2005 10:58 pm Post subject: |
Pocketgps wrote: | How many CD's do you have, a full set with the euro coverage consists of 4 cd's, if you have them then you would have a program on disc 1 called map export, that you load to your main pc
I did it your way it took a long time but it was perfect .It works with activsync .....can take over 4 hours but what the hell
Stu
itxweather Occasional Visitor
Posted: Mon Aug 08, 2005 10:50 pm Post subject: Re: Medion MD 95900 problems |
cityboy wrote: | Anybody point me in the right direction please!!!!
Not sure if you have got the SD Card problem fixed but the 95900 does not seem to like Kingston SD Cards, tried two of them and neither work, however Sandisk seem to work.
Best Regards. _________________ itx-weather.co.uk
http://www.itx-weather.co.uk |
Posted: Thu Aug 18, 2005 10:32 pm Post subject: |
Sorted!
Aquired a full set of European maps, bought a 512 Sandisk SD card and now have UK/Ireland as well as France on there with some space left for MP3's as well.
Thanks to all those who replied and yes there does seem to be a compatibility issue with certain SD cards as my two Panasonic cards, used in my camera, did not register.
Thanks again |
